Is it my XL1s, my 1.6 extender, or just me?!
Hey all,
Only with my extender attached do I get a very soft image when zooming out. Any thoughts? TIA, Randy |
G. Randy
An extender is an attachment to a lens that magnifies the original focal length intended for the lens and the results in terms of a quality image will never be satisfactory for the discriminating eye. I shoot football on a regular basis with my 1D and a 300mm lens (stills) and would like to get a 1.4 extender to get in closer but I do not want to loose clarity or sharpness of the image due to magnification so I just wait for the subject to come closer. I feel an extender is an inexpensive alternative to a longer lens and you end up getting what you pay for and I do not intend to ever use one with my XL1s. I do not know what you use the extender for but if you can somehow get closer and drop the extender you will be much happier with your image and you will be filled with gratification knowing you found a way to get closer with out your subject knowing. Gary |
>>>I feel an extender is an inexpensive alternative to a longer lens and you end up getting what you pay for<<<
Hmm, I paid $354 for it at B&H....not cheap.... for me anyway. Also, I don't recall having this problem before. Randy |
Warden
If you've eliminated all the other possibilities, then it probably is the extender. It magnifies the image, but it also magnifies any defects the lens has too.
Jeff Donald Carpe Diem Search DVinfo.net for quick answers | Where to Buy? From the best in the business: DVinfo.net sponsors |
#5 |
G. Randy. I have been useing the 1.6 extender on the XL-1 and now the XL-1s since 1998 and never had a problem with it. Although I must say I usually do not zoom through it. I have used it on the 16x servo and 14x manual with great results. I have used it for wildlife and birding trips. I have also used it with 1,2, 4 diopters for magnificant closeups of insects. One thing I was told by a sales rep in Atlanta, that you may or may not have heard about. When mounting it on the lens. Make sure the Canon is in the OFF mode, then attach the 1.6x to the lens FIRST and then attach the lens and extender to the body. I do not know why, but the rep told me it had to do with the way the camcorder reads the electrical information from the lens. I do not know, but my images are great. You might want to try it. Bob
#6 |
>>"If you've eliminated all the other possibilities, then it probably is the extender. It magnifies the image, but it also magnifies any defects the lens has too.<<"
What I was doing was maually focusing on a tight image and then zooming out slowly; when the image became too soft I would re-focus (looked good) but then when pulling out again it would become soft again...FWIW >>"Make sure the Canon is in the OFF mode, then attach the 1.6x to the lens FIRST and then attach the lens and extender to the body. I do not know why, but the rep told me it had to do with the way the camcorder reads the electrical information from the lens. I do not know, but my images are great. You might want to try it.<<" I will try that procedure Bob, and thank you for the reply, but considering the camera is in the off mode I just can't see what difference it would make. Thanks again guys, Randy |
#7 |
I have seen the same problem when using my XL1s with the extender, but unfortunately I never did figure out what the problem was. It happened to me twice when I was shooting in cold weather (0 - 10 degrees farenheit). Out of spec - I know. Usually this was no problem. Last time it happened I removed the lense and extender and cleaned the contacts on the extender. When I reassembled it, everything was fine. This could have been due to condensation(I was getting in and out of a vehicle). Maybe try cleaning the contacts. It sounds like your problem is constant. Mine has only been intermittant and is working alright now.
Nature Boy |
#8 |
Thanks Nature Boy, I'll try that.
Randy |
#9 |
just once more
Well, it's been a while since I've used the extender but after taking Phil's advice I noticed it still has the problem. However upon closer inspection I've noticed this XL1s doesn't hold focus even without the extender (fully manual, zoom tight, focus, pull out, zoom back in and it's softer) so I thought I'd check here one more time before I ship it for service. FWIW, my other XL1s doesn't do this.
Thanks, Randy |
#10 |
Sounds like a back focus issue. Is this the 16x servo lens or one of the manual lenses you are using?
If it is one of the manual lenses then you might try refocusing the back focus. If its the 16x servo, sounds like it needs a vacation at Canon. |
#11 |
It's the 16x servo lens. Well I was pretty much expecting it would need service (especially since the 2nd one doesn't behave this way) but just wanted a final opinion. Thanks very much Jonathan. Fortunately, it is covered with a Mack extended warranty, anyone ever have any trouble with them?
Randy |
#12 |
This is all very interesting stuff to me as a newbie.
I was about to buy the extender as I have done a couple of test runs filming some polo matches (for a new venture!) without having the extender - using the standard lens that came with our XL1s, and found two things. Firstly, we really need slightly more zoom, and secondly I found because of the nature of the game - it's not possible to zoom out to a fixed point and then back again because the zooming requirements are constantly changing. I found even without the extender that I was losing focus. I was using the camera's basic shooting option (easy recording) My questions are: 1) Can someone please recommend the best setting for this sort of work - Auto/Manual/TV or ? and with whichever is best, what further settings need to be tried or adjusted? 2) Will it be a waste of money buying the extender. 3) Should we be looking at one of the manual lenses available? or buying the adaptor and fitting another type of Canon zoom lens? Any help and guidance would be greatly apprecieted TIA John |
#13 |
I think anyone here will tell you manual and to never, ever use the 'easy" mode. 2) Will it be a waste of money buying the extender. The extender works great on both of my XL1s' it just magnified the focus problem I have with one and need to have adjusted. 3) Should we be looking at one of the manual lenses available? or buying the adaptor and fitting another type of Canon zoom lens? If you are shooting in easy mode I think your first step is to learn the camera's capabilities in manual mode (read the manual and do searches here), you may learn the stock lens is all you'll ever need (other than maybe the extender for the polo matches). Randy |
#14 |
#15 |
Thanks to both of you for your help - Well, back to the learning curve I think!!!!....
