Wired Color change? at DVinfo.net
Old February 21st, 2004, 07:16 AM   #1
Wired Color change?
Hi,
I was on a shoot, after viewing the tape for logging.
i have noticed that the color change from let's say normal to a red-orange tint.
How could this happend, does the Camera have a error? I had all setting on Manual.
here is a sample
http://homepage.mac.com/shaggyalienf...eTheater1.html
Thanx
Shaggy
Shaggy Franks is offline   Reply With Quote
Old February 21st, 2004, 02:07 PM   #2
Warden
Did the lighting change? How was the white balance set?
Jeff Donald
Carpe Diem
Old February 21st, 2004, 03:58 PM   #3
Hi,
no except for the laser in the Cabin.
I did the white balance under the used lighting
with a white paper if you mean that?
Shaggy
Old February 22nd, 2004, 06:44 AM   #4
Did it change once, or did it start to change back and forth at a farily constant rate? (can be caused by using high shutter speeds with flourescent or other discharge type lighting)
Is it related to scene content or camera angle, as in a shift from mainly artificial to natural light? (scenes with incandescent lighting can look much more orange, and the camcorder will see this while the eye automaticaly adapts)
Laser in the cabin? Could you describe the lighting conditions in the cabin and the camcorder settings?
dpalomaki@dspalomaki.com
Don Palomaki is offline   Reply
