HELP! Flickering line top/bottom of frame! at DVinfo.net
Old January 27th, 2004, 08:22 AM   #1
Hi - I have just purchased a second hand Canon XL1s - seems to be in good condition generally. Video taken with it looks superb apart from a little problem...
When I transfer the video to PC via Firewire there are two flickering lines about 2 pixels high - one at the very top of the frame and one at the very bottom.
I have read all the threads about the "black bar" problem but this seems to be different - I have tried putting the tape into my little Sony and the problem is still there (footage shot on the Sony is fine tho).
Any ideas please ?
Thanks, Simon.
Simon Phillips is offline   Reply With Quote
Old January 27th, 2004, 08:43 AM   #2
Hi Simon,
Believe it's very similar to the "black line" thing you've read about. Should not be considered an issue since it's outside of the TV-safe area. If your output is intended for computer screens instead of TV's, just crop the image to the TV-safe area and everything should be fine. Hope this helps,
Old January 27th, 2004, 08:45 AM   #3
Hi Chris - thanks for the answer. I kinda guessed as much but it is still pretty annoying! Do you think it is worth having it serviced by Canon anyway? Does anyone know how much a service costs in the UK ?
Old January 27th, 2004, 03:34 PM   #4
RED Code Chef
I don't think getting it serviced will help at all. It is definitely
outside the TV safe zone and Canon has clearly stated (forgot
where) sometime that the TV safe zone image should be used.
For most people this isn't a real big problem, this is why:
1) output to VHS tape or DVD will not reveal this "issue" on a TV. I'm not sure whether it would turn up on a projector
2) output to the web. Since you are not going to output at full resolution to the web there is no harm in cropping a few lines before resizing it to web resolution (even the resizing might get rid of it on its own)
3) A lot of people are letterboxing (ie, putting 16:9 black bars on top of your video) their footage for a more filmic aspect ratio. This will also remove those problem area's
Also if it really is an issue, just add blackbars that are 2 pixels
high on both the bottom and top. These will blend in nicely with
the pixels on the side of the image and no-one will ever know
you dropped a few lines of data.
Rob Lohman, visuar@iname.com
Old January 28th, 2004, 05:16 AM   #5
Hi Rob,
You are right. My first reaction was one of feeling slightly cheated but then I realised - "hey, what does it matter!" - I have played with the camera over the last few days and it is a very nice piece of kit. I actually think the balance is good (although most people complain).
I did a quick test shoot in my office with 2 redheads set up for light and both the XL1 and the little Sony TRV14E - both cameras were in full auto mode (XL1 on Green Square mode). The footage from the Sony was FAR superior - better focus and colour reproduction - much sharper in general. I am thinking that the XL1 really needs to be controlled in manual mode to get the best from it? Am I right ?
Old January 28th, 2004, 05:50 AM   #6
In the hands of a good shooter, the manual will produce better images than full auto mode.
The Canon image is different from the Sony, a bit softer and warmer. All depends on what you and your customer like. The XL1s allows more conrol over image color and sharpness than the older XL1.
dpalomaki@dspalomaki.com
Don Palomaki is offline   Reply
