Audio Inputs Mic/Audio 1/2 at DVinfo.net
Old January 19th, 2004, 05:47 AM   #1
Does anyone know if there is a marked difference in the audio input circuits between the on-board mic input and audio 1/2.
Here is my question...I have a Senn. EW112 lav setup...I can run the input of the receiver either into the onboard mic input or go to audio 1 or 2 and choose mic input via the menu. It appears if I connect to the on-board mic input the meter shows a bit more "punch". Curious to what other with similiar setup is doing and what would be the better audio choice....
Mark A. Foley is offline   Reply With Quote
Old January 19th, 2004, 08:17 AM   #2
The extra punch you are seeing is that the mic inputs are seeing the extra power from the Sennheiser. The mic normally receives its power from the smaller of the two jacks on the handle. Your problems may be that there could be impedance mismatch or overloading the input amp which may cause distortion.
I believe if you want to use Audio 2 the camera must be switched to 4-track mode. This reduces audio resolution from 16 bit to 12 bit. I run this way all the time since I like to use the on-board mic with the wireless mic.
If you want the higher resolution you should run your mic into audio 1 instead.
Nathan Gifford
Southern Cyclist Magazine & Productions
For quick answers try our Search!
To see me and Rob Lohman click here
Nathan Gifford is offline   Reply With Quote
Old January 19th, 2004, 10:03 AM   #3
Actually Nathan I'm not getting any distortion using the microphone terminal input...sounds good in either input....with the on-board input has a bit more punch to the audio....
I guess when all else fails get the book out....it appears the microphone terminal input is -59dBV and Audio 1 with MIC selected is -55dBV...guess it explains why the microhone terminal is a bit hotter...
Old January 19th, 2004, 01:07 PM   #4
Its not quite that simple. Your bodypack receiver has an adjustable output. Since you really cannot be sure how much power your bodypack is actually doing, you cannot be sure which is hotter. Not that this matters, if you are getting good results shooting the way you are, that's great!
Nathan Gifford
Old January 19th, 2004, 09:18 PM   #5
As you noted the MIC input is more sensitive than the Audio1 input, by about 4 dB. Other thins being equal, the mic input jeck will appear to have a bit more 'punch'
dpalomaki@dspalomaki.com
Don Palomaki is offline   Reply
