14x manual lens - Page 2 at DVinfo.net
Old April 18th, 2003, 08:19 AM   #16
Manual 14x Lens... foreground/background
I need advice, i'm looking to purchase the 14x manual Lens, but i wanted to know:
Can you use it to film the foreground in focus, while the background it out of focus?
If you can, can you
Then bring the background into focus?
Please advise if this can actually be done with the normal canon lens.
Cheers
Appologies for my ignorance... no excuses.
Tom
Tom Schan is offline   Reply With Quote
Old April 18th, 2003, 08:46 AM   #17
Retired DV Info Net Almunus
Welcome Tom,
What you refer to is "Depth of Field" (DOF). See Jeff Donald's article on the main site for full coverage of the fundamentals of this topic. In brief, yes you can but the relatively small rear aperture of video cameras (such as the 1/3" of the XL1s) presents limitations to shallow DOF.
Old April 18th, 2003, 09:25 AM   #18
Cheers Ken
Most appreciated.
So i know now it is worth purchasing.
Tom
Old April 18th, 2003, 09:34 AM   #19
It's an excellent lens. ( See my 16x review for photos and comparisons with the 14x.) I think its iris mechanism is the best that Canon has produced.
But, in itself, it will not deliver greater DOF control than your 16x standard lense, per se. It will, however, enable you handier control of that iris.
Old April 18th, 2003, 11:08 AM   #20
It will have the same depth of field as the stock lense.
The focus shifting technique you describe from front to back is called "rack focus".
It can be done with both lenses, but is much easier to do on the 14x manual lens.
Old April 18th, 2003, 07:58 PM   #21
I was under the impression that the manual 14x and manual servo 16x could both do a rack focus and the only basic diffenences where the 2x and the servo. Am I wrong?
Mark Argerake is offline   Reply With Quote
Old April 18th, 2003, 08:07 PM   #22
Yes, they both "rack focus" easily. The focus ring on both is completely manual and the black lens barrels of each are easy to mark with a white pencil if needed.
Mark, see my 16x review page (linked above) for complete notes on the 16x and 14x manual lens differences.
Old April 18th, 2003, 11:08 PM   #23
Ken, Your link doesn't work
Charles
'What we perceive to be may not be what we believe to be.'
Charles King is offline   Reply With Quote
Old April 18th, 2003, 11:12 PM   #24
Charles,
Hmmm...it works for me...it must be biased <g>. Here's the link:
http://www.dvinfo.net/canon/articles/article82.php
Old May 8th, 2003, 03:38 AM   #25
Manual 14x and Matte Box
I recently bought a 14x manual for my xl1s, and I read that I wont be able to use a matte box with it. The end of the lens rotates, and this obviously would cause problems. Has anyone a solution to this problem? I do not have the auto lens.
stephen
Stephen Birdsong is offline   Reply With Quote
Old May 8th, 2003, 05:39 AM   #26
RED Code Chef
If you have a mattebox then simply try it out and see what
happens. If you don't I know there are matteboxes out there
with support rods that allow the lens to rotate. I don't know
where I saw this so I hope someone else will chime in with
more info on this!
Rob Lohman, visuar@iname.com
Old May 8th, 2003, 08:11 AM   #27
No, I dont have a matte box. Im looking to invest in one.
Stephen
Old May 8th, 2003, 08:19 AM   #28
Basically matteboxes for the XL1 come in two styles:
1. Clamp-on, which mount to the front off the lens and cannot be used with either the Fujinon or Canon 14x lenses as their front elements rotate.
2. Rail mount. The mattebox is supported by rails that are fixed to a plate that mounts to the underside of the camera via the tripod mounting hole. This can be used with lenses with rotating front elements like the Fujinon and Canon 14x lenses.
Adrian Douglas is offline   Reply With Quote
Old May 8th, 2003, 08:21 AM   #29
Ok, Thanks Adrian.
The only Matte Box I know of for the Xl1s is the century optics. Does anyone have any suggestions about which Matte Box to use?
Old May 8th, 2003, 08:30 AM   #30
Stephen,
As well as the Century Optics mattebox, the Cavision Mattebox also has rails for use with the 14x lens
