Thread Tools
Search this Thread
When and when not to use the lens hood?
I've noticed with some of the shooting I've done with my xl1s, that I can see part of my lens hood in all four corners when I play back my footage on a tv or computer. It's not horribly noticeable, but definately bothers me. It's reall fuzzy. I think it might have something to do with shooting in low light.
Can somebody tell me when to use and when not to use your lens hood? Thanks! |
RED Code Chef
Are you sure? Aren't you seeing something other like a filter? I
can't remember ever seeing my hood showing up in any of my footage! It's basically always on my XL1S.
Rob Lohman, visuar@iname.com DV Info Wrangler & RED Code Chef Join the DV Challenge | Lady X Search DVinfo.net for quick answers | Buy from the best: DVinfo.net sponsors |
Outer Circle
Bo, you could get a larger/wider lens hood.
Rob, you think it might be my screw-on UV filter? I've got one on my lens? Maybe it is.
I've noticed that the few clips I have with the fuzzy, dark corners were shot in low light. |
#5 |
i've never seen the hood in mine at all.. i would shoot some footage with the filter off..
also it might be the tapes you're using too, if you're switching media. |
#6 |
Outer Circle
It shouldn't be because of the tape.
#7 |
Retired DV Info Net Almunus
Bo,
The only way the lens hood could encroach on your image is if it's improperly mounted. Remove it and carefully remount it. It must be fully seated with a twist. The Canon insignia should be on top. Filters can encraoch on the image, causing a vignetting effect. This, however, is generally only an issue when stacking two or more screw-ons and shooting at the widest angle. This should be trivial problem for you to diagnose. Take the filters off and test.
Lady X Films: A lady with a boring wardrobe...and a global mission. Hey, you don't have enough stuff! Buy with confidence from our sponsors. Hand-picked as the best in the business...Really! See some of my work one frame at a time: www.KenTanaka.com |
#8 |
<<<-- Originally posted by Frank Granovski : It shouldn't be because of the tape. -->>>
i have had issues with using different brands of tapes and the 2nd brand (sony) causing a "shadowing" towards the outer edge of the camera. i have also seen this issue in GL2's before. again, i think it's his filter, but if it's not.. a head cleaning and running 1 brand of tape may fix it. |
#9 |
I cannot imagne how tape could induce corner vignetting in a digital system. Head and tape problems cause digital errors - block and mosaic type effects in the image.
Effect of a filter stack or other external device is the most likely cause. It wil be more visible on a computer monitor due to lack of ovescan. A second less likely possibility is an internal lens defect. However, all lenses have some fall-offf toward the corners, this is most apparent with very flat subjects, e.g., somewhat underexposed plain white walls.
dpalomaki@dspalomaki.com |
#10 |
Don and Frank, this is the issue i was referring to. It is more visible in low light. It is due to switching tape media brands as different medias use different tape lubes that can react and gum up the heads. I have seen this issue in several camera, and it is a fairly well known one.
12mb mpeg2 clip, interlaced and no correction or effects of any kind done to it. Watch the top left and right corners, note "blur" does not correlate to zoom at all (as it appears when wide and tight) http://www.adamgeek.com/vignette.mpg |
#11 |
Adam,
I do not believe that the vignetting in the clip has any relation to switching tape brands or to tape at all. It is a common edge light fall-off phenomenon of all lenses, video and photo. It is related principally to the lens' design and to the iris setting. We've discussed this exhaustively with regard to the GL2 at this thread. Contaminated heads cause a completely different, and very distinct, problem.
#12 |
As far as I know the XL1s has interchangeable lenses. Are you using the standard ones together with the standard lenshood??
#13 |
What you describe sounds like vignetting, but I've also seen the hood of my Canon WD-58 in one corner (upper left) of my video clips. In that case, the hood was mounted with the incorrect rotation.
#14 |
<<<-- Originally posted by Ken Tanaka : Adam,
I do not believe that the vignetting in the clip has any relation to switching tape brands or to tape at all. It is a common edge light fall-off phenomenon of all lenses, video and photo. It is related principally to the lens' design and to the iris setting. We've discussed this exhaustively with regard to the GL2 at this thread. Contaminated heads cause a completely different, and very distinct, problem. -->>> Interesting.. i'll read the link in a sec. However, i have only had this problem once, it was after shooting using sony instead of Panasonic media, and after a head cleaning the issue was resolved. Furthermore, i had shot in that exact same location, from 3pm untill 10pm on nearly a dozen occasions, and this was the only one to cause the blur i posted. Perhaps it wasnt the tape issue and by chance i've never been able to replicate it.. i dunno. |
#15 |
Posts: n/a
I had this problem once when I was using a wide-angle lens. Didn't pay attention and unless I zoomed in a little from full, you could see the edges of the lens body in the corners. They were clipped when viewing on TV, thank god, but really noticeable and irritating in the NLE.
