Lense zoom noise on XL1s - Page 2 at DVinfo.net
Old May 8th, 2002, 12:45 PM   #16
Did some search on inet and found that extending distance between mic and camcorder in 1.5 times will reduce noise from camcorder servos by about 3-4db.
XL1s PAL, wide angle lens, all things lightwave, MA200.
Dual AMD MP1900+, 1gig of RAM, Canopus DVStorm, Nvidia Quadro4 750XGL, Promise IDE Raid.
Kairat Salikhov is offline   Reply With Quote
Old May 9th, 2002, 02:31 PM   #17
Capt. Quirk
I have had the same servo noises with my XL1s as well. Then I started mounting a shotgun mic on the accessory shoe. The audio isn't as rich, but you don't get the motor hum either. Ideally, I only use the on board audio as a reference anyways, and record into a hard disk recorder for final audio.
If Kairat has an unusually loud zoom motor, then I'm plagued with it too. Anybody else?
K. Forman is offline   Reply
