Problem with audio ( treble value too high ) at DVinfo.net
Old December 10th, 2003, 01:23 PM   #1
I have audio files with treble value too high. So the sound hears like there are noise.
How to fix that case ???
Sunarto Sosrosaputro is offline   Reply With Quote
Old December 10th, 2003, 02:32 PM   #2
We need a little more information in order to help you. Is this after you capture it to your NLE or just during playback? Are you using the on-camera mic or have you hooked up another mic via xlr?
I understand everything about nothing.
J. Clayton Stansberry is offline   Reply With Quote
Old December 12th, 2003, 11:23 AM   #3
When I playback in camera.
What program for fix sound ???
Old December 13th, 2003, 06:55 AM   #4
Two popular professional audio editing programs are:
Sound Forge
Adobe Audition (formerly Cool Edit pro)
dpalomaki@dspalomaki.com
Old December 13th, 2003, 12:19 PM   #5
You may also be albe to fix the problem within your NLE. Once you have captured your file onto your computer, check the audio filters. In Final Cut, you may be able to use the Low Pass filter or the equalizer. Also, check your camera settings. Good luck.
Old December 14th, 2003, 09:01 PM   #6
I have example audio file.
Where I can upload the example file ???
Old December 24th, 2003, 05:20 AM   #7
What was the source of the audio? It did not appear to be from the XL1 in that it was 44.1 kHz sample rate. Looking at frequency spectrum of the file, it has nearly constant amplitude up to about 12 kHz, ususual for live recordings.
Don Palomaki is offline   Reply
