DV Firewire..
I have a Canon XL1.
I just moved my computer and the Firewire link between them stop working. I figure it to be something with cable or card. I hope it has nothing to do with my cam. But just to be sure, if you put a firewire cable in your cam without it being connected to a computer, does it still say DV IN in the viewfinder? So only cam and cable, no computer. Does it still say DV IN or nothing happens in the viewfinder? Thanks /andreas |
RED Code Chef
If I remember correctly DV IN is always on with my XL1S. But
I'd have to check that to be sure. I'm currently not at the place where my camera is. Try different cables / cards if possible to see where the problem most likely is.
Rob Lohman, visuar@iname.com DV Info Wrangler & RED Code Chef Join the DV Challenge | Lady X Search DVinfo.net for quick answers | Buy from the best: DVinfo.net sponsors |
Another thing you can try is copying cam to cam. If that works you can elminate cam as being the source of your problems.
One thing to realize is that the firewire connector is somewhat delicate. I always use a 'hairball' to relieve stress on the firewire cabling by securing it to the front handle belt.
Nathan Gifford Southern Cyclist Magazine & Productions For quick answers try our Search! To see me and Rob Lohman click here |
I'm quite sure it's the computer (or I pray to god it is) but I just wanted to rule out the cam before I move on down the troubleshooting lane.
I don't have another cam, so I can't transfer. But I had to reinstall a friends computer one time. He had the same issue I have now. It didn't even help pulling out the card and re inserting it installing it all over. But when I reinstalled windows it worked. I hope I have the same problem.. |
#5 |
Hi Andreas.
Try this: Go to device manager Right click on the firewire port Choose uninstall Shut down the computer Unplug the power cord Remove the firewire card Switch on and boot windows After disk activity has stoped, shut down Unplug the power cord Insert the firewire card Switch on and boot windows After disk activity has stoped, go to device manager Check if firewire port is OK (no yellow exclamation point) Connect the firewire cable Switch camera on Windows should detect the camera If windows detects the camera you should be OK to capture Good luck and best regards, Arnaldo |
