Canon XL1 & XL1S Batteries / Battery Options - Page 11 at DVinfo.net
Old January 22nd, 2003, 10:10 AM   #151
Alastair Brown
Posts: n/a
In the UK try www.sabahoceanic.com I just order a BP941 5500mah for £34 delivered! Paid £62.50 for the same thing from Keene last year.
Old January 22nd, 2003, 12:23 PM   #152
I've always been reluctant to switching to 'no brand' batteries, but I'm aware that most of of the time these products come from the same plant...
Do these batteries from for instance www.sabahoceanic.com wear out faster, or drain faster? Or any other issues? Just checking before ordering :-)
Thanks in advance,
Bar3nd
www.raamw3rk.net
digital storytelling and vfx
Barend Onneweer is offline   Reply With Quote
Old January 22nd, 2003, 01:14 PM   #153
Barend,
Can't speak for sabahoceanic, but my Lenmar batteries are holding out just fine after 18 months of regular use. Hope this helps,
Old January 22nd, 2003, 08:47 PM   #154
Frederick Ross
Posts: n/a
Battery Belt
Does anyone know what a good battery belt is for the xl1s? Thanks
Old January 23rd, 2003, 02:07 AM   #155
Retired DV Info Net Almunus
We need more specifics to answer. What do you want to power with a battery belt? Most such power sources, such as Anton Bauer belts, provide 12v DC whereas the XL1s runs on 7.2v DC power.
Old January 23rd, 2003, 05:56 AM   #156
Warden
I use on rare occasions the NRG Research belts and their convertor cables The belt is a left over from my Beta SP days. It weighs about 8 pounds and can power an XL1 for days.
Jeff
Old January 23rd, 2003, 10:20 PM   #157
jukulu33
Posts: n/a
Jeff (and others)
You said you used the NRG on rare occasions. What do you use now--if anything?
Old January 23rd, 2003, 10:58 PM   #158
Warden
I use the Canon CH-910 and I use the Lenmar LIC 941. I carry 4 of the batteries and that can power and XL1 for 8 to 12 hours at a minimum. I occasionally use my belt to add stability (extra weight) to my tripod. The belt gets clipped over the mid-level spreader. I also use it when I won't be near a reliable power supply to recharge my Lenmar batteries.
Jeff
Old January 24th, 2003, 07:58 AM   #159
RED Code Chef
What's difference between 941 vs. 945 batteries
Hey everyone... I'm a bit confused as to the number for the
largest Canon battery. It is usually referred to as the BP-945
but Lenmar says it is a 941?? Can someone please clarify this
since I'm looking into buying one today.
Rob Lohman, visuar@iname.com
Old January 24th, 2003, 08:11 AM   #160
The Lenmar 941 actually has more juice than the Canon 945, so you're good to go. There's three basic sizes of the BP 9xx series batt, small, medium and large. 941 is Lenmar's designation for the large even though Canon no longer makes the 941 (now the 945). Doesn't matter as the 941 and 945 are the same physical size and a Lenmar 941 will outperform and outlast a Canon 945 anyway. Hope this helps,
Old January 24th, 2003, 08:23 AM   #161
RED Code Chef
Thanks for the info and fast response Chris, much appreciated!
I haven't found a Lenmar battery here yet, but some shops
has a different brand (unknown which one at this moment)
that also is designated as the 941. This one only costs $70,
so I'm gonna try it out.
No-one seems to have a Canon BP-945 here in holland and
they also cannot tell me how long it will take to order one. So
I'm looking at other options.
Thanks again!
Old January 24th, 2003, 10:26 AM   #162
you can look into the Power-2000 (sometimes refered to as the VidPro Power 2000) replacement for the 945.
I bought a couple of them and they were recommended to me here in a thread where I was asking for recommendations for replacement batteries.
They are 6000mAh batteries vs. the BP-930 which came with my XL1S which is only 3000. From my estimate (although I haven't had them long enough to get a lot of practical, field refernce) the 6000mAh should last around 2 hours. BUT it always depends on what you are doing with it.
Kevin Burnfield is offline   Reply With Quote
Old January 24th, 2003, 11:09 AM   #163
Posting suspended -- Contact Admin
Well, I'm looking for battery too. I'm thinking of getting two Lenmar LIC941, but want to know the charge time for this battery on standard Canon charger. Does anyone knows?
jonniesiri is offline   Reply With Quote
Old January 24th, 2003, 12:52 PM   #164
Warden
I usually charge them overnight for a full charge (8 to 10 hours). I use the Lenmar Mach 1 charger for a quicker charge. Full charge is 3 to 4 hours.
Jeff
Old January 24th, 2003, 01:49 PM   #165
If everyone seems to be happy with LENMAR batteries, any Brits or Euros know any good sites for cheap LENMAR batteries??? Preferable ones that accept GBP as payment!
Christopher Hughes is offline   Reply
