Ask-Noise in my sound ??? at DVinfo.net
Old November 2nd, 2003, 10:30 AM   #1
Why my sound isn't clear, there is a noise ( from audio 1 / external microphone and direct microphone ).
My sound will be heard like broken sound.
.......cet....cet...........cet.........................cet....cet.....cet......
Sunarto Sosrosaputro is offline   Reply With Quote
Old November 3rd, 2003, 01:41 PM   #2
Might be several things.
1. Do you hear the sound when playing back the audio on the camcorder?
Yes
Check your mic gain, mic cable, mic battery(if your mic has one. The standard mic does not.)
No
Problem is in you computer or editing package
2. Problem only happens on computer?
Make sure editing package supports the audio weight you have selected (16 bit or 12 bit).
Set your editing package to same audio weight as the camera is set for.
Make sure you editing package supports 12 bit audio. If not be sure to keep the cam set to 16 bit audio mode.
Nathan Gifford
Southern Cyclist Magazine & Productions
For quick answers try our Search!
To see me and Rob Lohman click here
Nathan Gifford is offline   Reply With Quote
Old November 5th, 2003, 02:55 AM   #3
That sound only in my computer.
When recording, I didn't hear that sound.
I recording 3 cassette. This case only for the first cassette.
Old November 5th, 2003, 01:01 PM   #4
Which editing package (Final Cut/ Vegas/ Premiere) are you using and what operating system (Windows/Mac) are you using? I think your problem has something to do with you PC's configuration.
Nathan Gifford
Old November 6th, 2003, 12:42 PM   #5
i using premiere, os Windows 2000. I using firewire to transfer. I confuse, because that case just for certain cassette. I using sony cassette
Old November 6th, 2003, 05:31 PM   #6
I still think your problem is with the computer's configuration. Make sure you are using a recommended firewire board for Premiere. Select good audio and video cards. Keep the minimum number of programs on (they can slow down the PC is they are kept running). For a minimum have 512MB RAM.
Use one manufacturer with your cam as this will probably limit dropped frames problems.
Nathan Gifford
