#91 |
Robert
You need to send the camera to Canon Service. Contact info on the XL1 Watchdog at www.dvinfo.net -- "The XL1 Skinny" |
#92 |
solar panels
You can always charge a car battery during the peak hours of sunlight. Then connect the car battery to your charger this way even if there is a flactuation of the sun intensity the car battery will still be steady in giving energy to your charger.
Opps sorry if its Cambodia it might be harder to carry a car battery to the jungle. someone who uses solar panels for energy |
#93 |
Most consumer VHS decks to not do a timecode.
You can create a window dub from the XL1 analog output. In VCR mode you would use the remode to turn on the time code display. |
#94 |
Making my own adapter for a Fuji lens????
Ok this is what is in my head I have an expensive Fuji lens16x-6.7on my JVC -X2B which is a great camera . Im trying to sell the camera. But am seriously wanting the new XL1s. I used the XL before and I hate the focus . So why cant I buy a cheap canon lens and switch mounts with the Fuji. Shouldnt that work? As long as the screw mounts line up that would work ...right? I still have to buy the adapter right? Even if I could do this?
Tony B |
#95 |
You can do it but it will be expensive, besides that lens is for a 1/2 inch camera and the XL1 is 1/3 inch (focal lengths wil be longer, not wide enough). You'll have to take off the motor and grip handle too.
#96 |
Quantum Productions
It looks as if they did use a new, longer EVF cable as I requested during my servicing! It's all working well now and I'm happy! :)
Adam Wakely, Quantum Productions |
#97 |
Peak VST
Does anyone have any experience with the "mono to stereo" DSP function in Peak VST? If so, any and all info (how well does it work, why did you use it, quality of output, limitations, etc...) would be appreciated. Could (should) I use it to convert mono from Sennheiser ME66 into stereo? Not interested in doing any hardwiring with splitters and the like.
esquared |
#98 |
I use Peak VST almost daily and have found it to be one of the best 2-track audio editors on the market. You should have no problem making the conversion from mono to stereo.
#99 |
Making a film Print and Shutter Speed
Will the alteration of the shutter speed affect in anyway any future transfer of the DV to film.
Eduardo |
#100 |
Retired DV Info Net Almunus
The only folks that can answer this are the folks at your transfer house. I suggest selecting one before you shoot frame one and consulting with them on what their requirements are.
Lady X Films: A lady with a boring wardrobe...and a global mission. Hey, you don't have enough stuff! Buy with confidence from our sponsors. Hand-picked as the best in the business...Really! See some of my work one frame at a time: www.KenTanaka.com |
#101 |
Posts: n/a
Letterboxing with the XL-1
First I would like to explain my setup, I have a standard XL-1 (2000) vintage with a 16 X lens. I have purchased an after market Matte box called an Image 2000 that attaches to the front of the Lens.
I was wondering how I could apply a Hard matte plate to this type of setup for doing a Letterboxing effect. I know I could apply a Letterbox in my editing program (Final Cut Pro) but this takes too long to render out. Any ideas? Thanks Dennis Morgan St Louis |
#102 |
Hello Dennis,
I don't have a suggestion for you per se, having never done this myself. But I'm curious about why you just want to mask-out the top and bottom of your lens' (4:3) image. Are you trying for a faux anamorphic look? It seems to me that if you mask-out parts of your image you may have some formidable focus and exposure issues that you'll have to compensate for.
#103 |
Calibrating video monitors.
I am using a XL1 with a Fujinon lens. Does anyone have any good methods for calibrating and color correcting monitors used for video taps?
Eduardo |
#104 |
Hello Eduardo,
Video University's site has a pretty good instructional page on this subject at: http://www.videouniversity.com/tvbars2.htm Note, however, that the instructions require that you display true SMPTE color bars for the calibration, something that the XL1 cannot do. (The XL1's bars are not SMPTE-compliant, but the XL1s bars are.) Your editing software might be able to generate true color bars which you could then record to tape to display for calibration. If not, you might be able to just wing-it with the XL1's bars and then use flesh tones to fine-tune to taste.
#105 |
Optex Digilite 15, or Canon VL-10i?
I am looking for a small/light weight video light < $150 for fill-in for less than 5 feet closeup.
Does anyone have experience with Optex Digilite 15? I found some feedback on Canon VL-10i, but not on Digilite 15. |
