XL1 / XL1S various posts - Page 50 at DVinfo.net
Old March 6th, 2003, 08:51 AM   #736
Azden Mics
HOW good are the AZDEN Mics?? for the Xl1s with beachtek???
guerrapato is offline   Reply With Quote
Old March 6th, 2003, 10:12 AM   #737
Azden Mic vs. ME66 ??? anyone...
Azden is cheaper! Is it as good as the ME66
Old March 6th, 2003, 01:17 PM   #738
There are plenty of posts on the Azden. They work fine with the XL-1. If you would like to read more try Azden Search Results.
Nathan Gifford
Southern Cyclist Magazine & Productions
For quick answers try our Search!
To see me and Rob Lohman click here
Nathan Gifford is offline   Reply With Quote
Old March 6th, 2003, 03:52 PM   #739
According to the LAFCPUG, no, the Azden is not as good. They do a lineup of 3 shotgun mics. It's probably been linked to from here before.
http://www.lafcpug.org/review_shotgun_mic.html
Brian M. Dickman is offline   Reply With Quote
Old March 6th, 2003, 05:45 PM   #740
Depends on which Azden mic, Some are a lot better than others. Keep inmind that Azden is a consumer/prosumer product line, and none will match the ME66/K6 for example.
Also, some folks have encountered level issues with the SGM-X. It has a relatively high output impedance.
Old March 7th, 2003, 07:29 PM   #741
I have seen that site before, but its always good to get other opinions. Anyone know of any other sites with MIC comparisin tests???????
Christopher Hughes is offline   Reply With Quote
Old March 12th, 2003, 05:05 AM   #742
Multitrack Recording Advice Requested
I wish to record at least 4 microphones on separate tracks. I will also be recording ambient sound via the XL1s on two 16 bit tracks.
Since I want to record in 16 bits or higher, I need to use a separate audio recorder. I would prefer to use 24 bit recording.
I am considering a TASCAM TM-D1000 digital mixer and a TASCAM DA-78HR 24 bit (8 channel) recorder.
I welcome other thoughts and recommendations from this forum.
Dan Keaton
Augusta Georgia
Old March 12th, 2003, 05:23 AM   #743
What are you recording? What is the venue?
Old March 12th, 2003, 05:29 AM   #744
Dear Don,
I want to be flexible. Some will be an Elvis Tribute artist, live. Others will be presentations, meetings, racing events, etc.
I want to do the mix after it is recorded on separate tracks.
Dan Keaton
Augusta Georgia
Old March 15th, 2003, 04:05 PM   #745
Mini XLR to XLR adapters
Please help!!!
I am new to this group but am looking forward to reading all the interesting tech info I see here.
I am a Bigfoot researcher (since 1972) and have been in about 6 documentaries on the subject. I have not been the happiest with the results and so am working towards making my own documentary. I am going to school to learn how to do this and have started getting the equipment. I am not rich but I try to get the best equipment I can to do the job. Right now I have a problem...
I have an XL1s with a MA-100 attached. It has the regular size XLR female plugs, but I have a Sony ECM-55SPT/ECM-55BPT electret condenser lav mic I want to hook up with it by way of cable and it has a mini XLR female plug.
Question:
Is there an adapter available and do I need it to have phantom power? The paper work with the mic says it is hooked up one of two ways... with power requirements either 1.5v or 5v, I don't understand this... either it is one way or the other I thought. It states the mic cable is :2.3mm(3/32in.) dia., 3m (10ft.) long 2-conductor shielded cable (pig tail)."
Two of the film's I was in, used film (16mm and 35mm) but even they used this lav setup. Sometimes they had the lav hooked up to a wireless but the static soundbites were with a corded lav.
Rick Noll
Rick Noll is offline   Reply With Quote
Old March 15th, 2003, 07:16 PM   #746
Retired DV Info Net Almunus
Welcome Rick,
I think the connector that you're looking for is called a "P3" connector. I also recently searched for such an adapter and found them for sale on Samson's site. Perhaps this will work for you, too.
But I have two Sony ECM-55B lavs, just a bit different from yours, which have an inline power adapter (ie. battery holder) that plugs between the mics and the camera. I actually believe that this is what you'll need, too. My mics came with this adapter but you may be able to buy them separately. Check with Sony's site and/or B&H Photo's site to see if the adapter is available separately.
Old March 16th, 2003, 06:46 AM   #747
lightweight tracking solution
Does anyone know of a lightweight tracking solution, something like GripControl's "e-track", just for tracks of up to 3 feet. Something that could be mounted on a tripod, and take about 4 kilos of camera (mini 35, XL1S and Nikon prime lens). The GripControl e-track is just too heavy and a little too big.
Mike Bluestone is offline   Reply With Quote
Old March 16th, 2003, 08:10 AM   #748
Outgrowning Case?
I made a mistake and purchased the HC-3100? System Hard case from Canon for my camera. It's kinda small and better fitted to being case for some lights than a camera.
i found a way to pack in the ma-200, cavision matte box, microphones , cords, tapes, batteies, tape etc. to be honest, it fits best when i leave the lens and B&W viewfinder on, because there is no place left in the bottom of the box for it seperately.
Is there a roomier case anyone can recommend?
John Threat is offline   Reply With Quote
Old March 16th, 2003, 11:42 AM   #749
Warden
ETrack is the only one I'm aware of, but I'm sure there are others. You might check with some of the big rental houses. You could probably build a short, light duty one for under $500.
Jeff Donald
Carpe Diem
Old March 16th, 2003, 09:15 PM   #750
Here are some XL1 hardshell case options.
Chris Hurd is offline   Reply
