XL1 / XL1S various posts - Page 10 at DVinfo.net
Old March 9th, 2002, 08:39 AM   #136
You might want to call K&H in Vermont (they make the PortaBrace line) at tel. (802) 442-8171 and ask for Scott Swinarton or John Fairley. If they can't answer this question directly, they'll point you to someone who will. Let us know what you find out,
Old March 9th, 2002, 08:47 AM   #137
Hi Phillip,
Actually yes, the audio tracks on the XL1 and other DV camcorders are recorded discretely, separate from each other, and you can re-mix them in post as long as the levels are right when you recorded them (not too high, not too low).
To make sure your audio is in an acceptable range, you'll want to watch the audio levels meter on the camera and adjust your levels accordingly.
The MA100 allows for two XLR inputs, but the MA200 allows for four XLR inputs. A separate mixer gives you some more flexibility... if you have four XLR audio sources but you don't have an MA200, then you can use the mixer to get all four sources to the camera. However the mixer may only have two channels of output, meaning when the audio is blended in the mixer, it's that way for good. You can play with the levels but you can't change the mix.
However having a separate mixer is one way to use multiple audio sources and still record in two-channel 16-bit audio on the XL1 instead of four-channel 12-bit audio.
16-bit audio is DAT quality; 12-bit is CD quality. To some folks this is a big deal but to others it isn't. You should guage for yourself and choose what you need. Hope this helps,
Old March 9th, 2002, 02:38 PM   #138
dialisproductions
Posts: n/a
Thanks for the message. I phoned yesterday and I was told that mxc-32 case most definitely won't fit the FP-33 mixer, but the mxc-33 case will fit the FP-32A and Fp-33 mixer. The Fp-32 mixer is slightly different in dimensions.
Old March 10th, 2002, 02:38 AM   #139
dtnelson66
Posts: n/a
Sakar batteries
i saw some posting about Lenmar batteries. Has anyone tries Sakar batteries. I've seen some that claim to last 6 hours (BP-941L for around $219.99) and one that lasts 4.5 hours (BP-930L for around $139.99).
If anyone has tried these batteries, do they hold ther charge well? What about memory and total life of the battery?
Old March 10th, 2002, 12:33 PM   #140
I've had the bp941L for 20 months- love it - no problems. I think I bought it from NYC for around $129. send all of them an e-mail requesting price and shipping
B. Moore is offline   Reply With Quote
Old March 10th, 2002, 01:08 PM   #141
dtnelson66
Posts: n/a
Thanks.
Old March 11th, 2002, 01:29 AM   #142
dtnelson66
Posts: n/a
built in ND filter?
I thought I saw something at one time about the XL1/XL1s having a built-in ND filter (of sorts). But now i can't seem to find any info to confirm that. Am I confusing it with the Sony VX2000 (another camera I've had even more experience with) or am I completely loosing my mind.
Derrick
Lompoc, CA
Old March 11th, 2002, 02:48 AM   #143
Retired DV Info Net Almunus
Your recollection is correct...kinda. The XL1/XL1s' 16x auto lens has a ND filter built-in. It's not a function of the camera body.
Old March 11th, 2002, 10:53 AM   #144
See the XL1 Watchdog FAQ at www.dvinfo.net/xl1faq.htm and also The XL1 Skinny and XL1S Skinny at www.dvinfo.net/xl1.htm -- hope this helps,
Old March 11th, 2002, 04:21 PM   #145
_redone_
oops!
This may stray from away from the usuall topics but..
has anyone ever droped their xl1 yet???
I dropped mine last weekend....nothing major but i noticed that
the inside lens plate popped off alittle in the side..
just some screws came half way out which in turn had to screw them
back in. ,..also decided to play it and see if it still worked..
the funny thing is it gave some pixelated image mess for the first 5 seconds
and then played fine there on out. everything worked fine after that but whew!, i though dropping my cell phone was bad untill now.
just incase..does cannon still repair XL1's now that they have the XL1's??
if so how do i go about sending it in for repair if i ever drop it again...?
Adam Lawrence is offline   Reply With Quote
Old March 11th, 2002, 05:48 PM   #146
Quantum Productions
Yes they do as I just got my XL1 back from Canon not long ago. I'm sure they always will.
As for dropping your XL1......DOH!
Adam Wakely,
Quantum Productions
Adam Wakely is offline   Reply With Quote
Old March 12th, 2002, 01:28 PM   #147
DV to Beta SP or DVCPRO (for example)
I do not have the ($) capability to take my dv into DVCPRO via firewire. I'm left with s-video or composite. I know the deck I record on to is a whale of an expensive deck, so I assume it has decent (not consumer) filters to make a nice transfer via the analog inputs.
Does anyone have any insight into whether I should use one over the other? It seems that some places use the composite plugs whereas I would think that s-video would be the way to do it.
Does anyone know if the firewire input board on Pana DVCPRO decks allow a clean transfer? I know that from D8 to DV and vice/versa is fine. So is it safe to assume that if the rec. deck (dvcpro) had the firewire input, that I could do a straight transfer?
John Klein is offline   Reply With Quote
Old March 12th, 2002, 04:07 PM   #148
Leaving battery on camera
Canon makes it very well known that you shouldn't leave you battery on your camera if you're not using it because it will drain you battery.
Well I think if you keep on taking off and putting on the battery directly to the camera , you'll probably have to replace the camera body because something is sure to break.
SOLUTION: 1) get the MA-100 2) get the CH-900 dual charger/holder with part # DC-915 which connects the Charger Holder to the side of the camera (included with CH-900)
Go to Radio Shack.
Pick up a one wire on/off switch (2 to a box $1.98)
and a small black plastic box 1 1/2" W by 2" L by
1/2" H ($1.78) Cut one of the wires on DC-915, solder to on/off switch, use dremil to cut out hole for switch, close to one side, drill holes in each end of plastic case to fit wires in & out. RESULT: you can now leave a battery on camera, turn off switch and store camerain case always ready to use.
without draining battery or camera transport system taking a beating..
Old March 13th, 2002, 08:42 AM   #149
AnthonyS
Posts: n/a
L2 and XL lenses
I have the Canon L2 and im wanting to upgrade to the Canon XL
digi cam.I have several L2 lenes. I was wondering if the lens
mounts are the same for the L2 and XL cams, and will the L2
lenes work on the XL with no problems.
Old March 13th, 2002, 06:42 PM   #150
No. See the XL1 Watchdog at www.dvinfo.net/xl1.htm -- go to Articles Menu > Lens & Optics > Can I use a VL Series lens on my XL1? by Don Palomaki.
Chris Hurd is offline   Reply
