EF Lens adapter / EF Lenses / EOS Lens - Page 18 at DVinfo.net
Old September 24th, 2003, 05:58 AM   #256
No apologies required... Thanks for sharing, Gareth.
VB
Virginia Benedict is offline   Reply With Quote
Old September 26th, 2003, 05:12 AM   #257
EF Lens Adapter...new focal length
I'm considering purchasing the EF Lens adapter, along with the EF 17-40 mm f/4L USM lens (ultra-wide zoom). I understand that the focal length will increase 7.2X. Won't that affect the degree of wide angle at the most open position, originally 104 degrees, decreasing the width of view?
Jeffrey
Jeffrey A. Dear is offline   Reply With Quote
Old September 26th, 2003, 08:11 AM   #258
you're definitely not gonna be able to shoot wide- but I did get really nice results with a 50 mm- ...the EF adapter and a decent EOS lens makes for absolutely sharp video- you're in for a treat!
Steve Nunez-New York City
www.stevenunez.com
Steve Nunez is offline   Reply With Quote
Old September 26th, 2003, 04:11 PM   #259
Widest angle recommendation...3X?
What is the widest angle lens possible with the XL1s, the 3x wide angle video lens?
Jeffrey
Old September 26th, 2003, 10:51 PM   #260
The 3x lens is the widest lens available. If you want wider you can go with a fisheye or a Century Opticswide angle adapter.
Adrian Douglas is offline   Reply With Quote
Old September 27th, 2003, 06:11 AM   #261
Keep in mind that the 7.2x focal length change is an approximation based on relative field of view. Just as the 5.5 mm wide position of the standard lens roughly corresponds to a ~40 mm lens on a 35 mm still camera - the 7.2 factor.
When you move the 35 mm still lens to the XL1 you are using the lens on a much smaller image sensor (nominal 1/3" CCD rather than a ~1"x1.5"" frame of film, thus the apparent telephoto (smaller field of view) effect.
dpalomaki@dspalomaki.com
Old September 27th, 2003, 12:05 PM   #262
Thanks for feedback...
Thanks for the great feedback. For now, I'll try the 3x wide angle.
Old October 4th, 2003, 03:54 PM   #263
EOS lenses: conversion factor for close focusing distance?
Hi there-
I understand that using eos lenses on the XL1s multiplies the focal length by a factor of 7.2. I'm shopping EOS lenses and I'm wondering if there's a conversion factor (or a guesstimation method) for the closest focusing distance of an EOS lens. I'd also be interested to hear how well focus can be judged through the standard viewfinder. Thanks for your time!
Jeremy
Jeremy Monroe is offline   Reply With Quote
Old October 4th, 2003, 04:02 PM   #264
Warden
Minimum focus distance will stay the same. Judging focus is difficult for most people using the standard color view finder. Practice with standard view finder helps, but many users switch to a supplementary LCD or CRT monitor to help judge focus.
Jeff Donald
Carpe Diem
Old October 5th, 2003, 08:02 AM   #265
A minor point: the focal length remains the same, but because the CCD is much smaller than a 35mm film frame, the effect on the field of view is as if the focal length was 7.2x longer.
For close focusing (closer than the standard lens) consider a diopter adapter. High quality models avalable from Canon and Century, low cost "close-up" adapters offered by several filter makers.
Old October 6th, 2003, 01:17 PM   #266
Thanks for the help!
Old December 23rd, 2003, 10:07 AM   #267
Location: Augusta georgia 15min. from Aiken S.Carolina and 2 hours from Atlanta
XL EF Adaptor vs. mini35
are the results and science of theXL EF adaptor combined with 35mm canon
still lens the same as using the mini35 or the augus35 that is now currently in production on this forum
if not, what are the differences?
thanks in advance.
Patrick Falls is offline   Reply With Quote
Old December 23rd, 2003, 10:14 AM   #268
RED Code Chef
No it is not. The difference is, is that the Canon EF adaptor
increases the focal length of the lens 7.2 times (so the lens
"zooms" in much more and is 7.2 times less wide). Because of
this you are also loosing the DOF (Depth Of Field) characterics
of the 35mm lens.
The mini35 (and Agus35) use a glass inbetween the lens and
the camera to capture the full frame and keep the DOF the same.
Rob Lohman, visuar@iname.com
Old December 23rd, 2003, 07:02 PM   #269
cool
thanks for clearing that up for me Mr. Lohman. i guess i'll be waiting for a commercial version of the Agus35, i can't wait until someone has a good working model that can be used on the xl1.
Old December 24th, 2003, 12:19 PM   #270
RED Code Chef
Ofcourse there is a commercial version already available: the
mini35. If you want to buy it, it will cost you around $8000
excluding lens(es). Ofcourse it is available in a lot of countries
as a rental unit as well.
Keep in mind that the mini35 or any other unit that will let you
use 35mm lensen will require a very good knowledge of your
camera, shooting experience and knowledge / experience with
35mm lenses. It is much more difficult then a DV lens!!
