XL1s Sound problem - FRUSTRATING!!!! at DVinfo.net
Old October 9th, 2003, 11:47 AM   #1
Hey all -
I'm trying to lay off a VHS copy of a Final Cut Pro document, using a friend's Canon XL1S as a DV deck. I am running a firewire connection from my FCP system to the camera, then I am connecting the camera to a VHS deck using a standard RCA cable.
The problem? I am getting video through to the VHS deck, but I am not getting any audio. When I plug a headphone into the camera, I am still not hearing audio. It's as if the audio is not making it into the camera at all.
Is there some sort of audio input setting I need to know about with the XL1s? What about Final Cut? Any advice anyone could send me would be greatly appreciated.
BTW, the version of Final Cut I am using is 3.0. Does that make a difference?
Thanks.
- Steve Janas
Steve Janas is offline   Reply With Quote
Old October 9th, 2003, 12:50 PM   #2
You do have the audio cables plugged into the correct connectors on both the cam and the recorder?
Nathan Gifford
Southern Cyclist Magazine & Productions
For quick answers try our Search!
To see me and Rob Lohman click here
Nathan Gifford is offline   Reply With Quote
Old October 10th, 2003, 11:19 AM   #3
Is the camera in VCR mode?
Nori Wentworth is offline   Reply With Quote
Old October 11th, 2003, 12:51 PM   #4
Is the audio in your FCP project at 16bit with a samplerate of either 48k or 32k?
Bob Maple is offline   Reply With Quote
Old October 12th, 2003, 02:56 PM   #5
I have to check on the sample rate issue. I do know that audio recorded at a different sample rate from the one specified in sequence settings must be rendered before you can hear it, but I don't think that's happening here.
After I posted the message, I heard from another friend who said he had to get both RCA connectors replaced on his XL1. It leads me to wonder whether this problem is endemic to the Canon XL1. Can anyone supply some insight?
- Steve Janas
Old October 13th, 2003, 10:23 PM   #6
The fact that there is no sound when you plug in your headphones probably eliminates the RCA jacks as the culprits. I would check FCP or some other Mac settings. Restart if you haven't done that yet.
Nature Boy
Phil French is offline   Reply With Quote
Old October 13th, 2003, 10:25 PM   #7
Play a tape in the camcorder. Does it have sound? If it does look at FCP.
Nature Boy
Old October 14th, 2003, 03:46 PM   #8
Never had any problems with RCA connectors. If a tape you recorded will play on the RCA connectors then the problem ain't in the cam.
You might check to see if you have program audio track muted in FCP.
Nathan Gifford
