Metallic "teeth on foil" sound on audio peaks at DVinfo.net
Old March 19th, 2009, 08:55 AM   #1
I had a off-and-on problem with audio on my XL-1. Regardless of the mic used (on camera, wireless lav or handheld), I sometimes get a short, annoying metallic noise that only shows up in the peaks of audio when recording voice. The levels are fine and it's not distortion from too much gain. Even if I turn the gain to a below normal level, I can still get the noise in the peak areas. I can't hear it while monitoring recording. Oh, and if I'm not dreaming, it happens more when recording female talent vs. male (perhaps the higher frequency of a woman's voice?).
It's due for a tune-up, but I'm curious if anyone else has experienced this problem and if a simple tune-up/realignment, etc. took care of it.
This camera is close to "retirement" so I don't want to invest much more money than the cost of a tune-up.
John Paulsel
Highpoint Productions
"I'd do it for free but I don't!"
John Paulsel is offline   Reply With Quote
Old March 19th, 2009, 09:01 AM   #2
I said "had" and meant "have"
Didn't want to imply that I no longer have the problem! I still have it occasionally.
John Paulsel
Old March 19th, 2009, 05:19 PM   #3
This is likely an electronic issue within the audio system with a high-frequency spike going into the clipping zone. But just maybe it might simply be a bit of loose crud like a sliver of dried grass or a hair fragment inside the microphone capsule or maight also be a ripple in the mylar diaphragm which might be causing a particular sensitivity in a narrow frequency band.
Try turning the camera upside-down, then face-down whilst holding it close in front of an operating desk fan operating at its slowest setting and see what that does to it. No warranty of satifactory cure is made either express or implied.
Old March 19th, 2009, 05:51 PM   #4
What you describe sort of sounds a bit like a clipping situation.
Tell us more about your configuration (including adapters, mics, sources, etc) and settings (including gain seetings) of the camcorder when this happens?
Is this in capture audio only, or in analog playback form the camcorder as well?
Can you post a link to a few seconds of the audio (in a .WAV file) that exhibits the problem?
dpalomaki@dspalomaki.com
Old March 19th, 2009, 07:29 PM   #5
That metallic description could be used to describe playback I experienced on my XL1s. I had it serviced and it solved it.
Old March 26th, 2009, 05:31 PM   #6
Metallic audio sound
Thanks for replying. Don, I'm using the standard XLR adaptor with a Shure wireless UP4 portable receiver, U1UA transmitter and a standard lav. I can't duplicate the problem anywhere else except on the XL1. I also get the same intermittent problem using the standard on-camera mic with a wind sock. I've also tried a wired Shure mic and still had the problem.
Setting-wise, I've tried everything... manual...auto...recording a bit low and bumping up in post, etc. Doesn't seem to matter. I've tried cranking the gain just to see if it got worse; it didn't.
I can't hear it when recording either through the camera monitor or the Shure monitor, but can hear it during camera playback. It's also audible when I playback on a Panasonic DV recorder deck that I use for capture.
The real pain is it that it is intermittent. I'm sure it will work just fine if I send the camera in for repair. Again, this camera is just about at the end of it's life cycle for me so I don't want to spend much to fix it.
John Paulsel
