A red dot on my footage at DVinfo.net
Old February 26th, 2009, 06:54 AM   #1
I have a small red dot in the footage after I capture it. It shows up more when its dark.
What can I do?
--Canon XL1--
http://www.richardgrebby.co.uk
Richard Grebby is offline   Reply With Quote
Old February 27th, 2009, 09:35 AM   #2
Sounds like a bad pixel. If the dot shows up even worse at high gain then you most definitely have a pixel going bad or already gone. Try a couple of black balances if your camera will do that and see if that clears up the problem. If not your probably just out of luck. Broadcast cameras will often allow you to remap bad pixels but I don't think the XL1 does.
"The good thing about science is that it's true whether you believe it or not." Neil deGrasse Tyson https://www.nautilusproductions.com/
Rick L. Allen is offline   Reply With Quote
Old February 28th, 2009, 08:47 AM   #3
High gain, slow shutter speed, and low light or dark situations with simple/flat image backgrounds can cause bad pixels to show up or become more apparent in an image. One way to address this in post is to make a pixel mask to hide the red pixel when you edit.
dpalomaki@dspalomaki.com
Don Palomaki is offline   Reply
