MA-200 XLR audio adapter questions - Page 8 at DVinfo.net
Old August 30th, 2003, 07:31 PM   #106
MA-series Microphone adapters
do the XLR inputs supply phantom power or is an external power supply needed?
Bryan Gateb is offline   Reply With Quote
Old August 30th, 2003, 08:28 PM   #107
If you are monitoring on the camera make sure the audio monitor is to either mix or ST-2.
Your NLE may not support 4-track audio. Try getting a copy of Scenalyzer. Its cheap and comes highly rated.
Nathan Gifford
Southern Cyclist Magazine & Productions
For quick answers try our Search!
To see me and Rob Lohman click here
Nathan Gifford is offline   Reply With Quote
Old August 31st, 2003, 06:05 AM   #108
Hi There,
I have been playing it back on NLE using Premiere 6 with DV Storm.
I've just played part of the tape back through the XL1 and listening through the headphones it is recording from both mics.
Does this mean Premiere 6 with DV Storm doesn't support 4 channel?
Gareth
Gareth Trezise is offline   Reply With Quote
Old August 31st, 2003, 06:31 AM   #109
Warden
No phantom power is supplied by the Canon MA-100 or MA-200.
Jeff Donald
Carpe Diem
Old August 31st, 2003, 06:57 AM   #110
Hi,
Have just read another thread in the post production forum by Ross Watson which has nailed the problem.
With premiere I need to make sure settings capture the 3rd & 4th channel and drag both the avi file and separate audio file for channel 3 & 4.
Thanks Don & Nathan. Both your comments about 4 channel audio capture and reading the other post has sorted it.
I thought I wasn't to far from the solution because I was sure I had set the equipment up right, which I had.
Thanks again.
Gareth
Old August 31st, 2003, 09:44 AM   #111
4-channel audio is a really neat feature on the XL-1, but it can really cause you some grief your first few times you use it.
Nathan Gifford
Old September 1st, 2003, 04:19 AM   #112
weak :(
thanks for the answer though -- looks like i wont be able to use any of my condensor mics unless i buy and external power supply :P
Old September 5th, 2003, 04:57 PM   #113
MA-200 questions
I have a few questions about the MA-200 if anyone can answer them...
1) How do you adjust the audio levels for the 4 different channels? I don't see 4 audio controls on the XL1S.
2) DV magazine said the MA-200 feels "loose" and the sound of it jerking around can be picked up by the on-camera microphone. True?
3) Does the MA-200 help balance the front heavy XL1S?
Bill Edmunds is offline   Reply With Quote
Old September 5th, 2003, 05:25 PM   #114
Warden
The MA-200 gives my camera a much better front, back balance. I've never picked up any noise from my MA-200.
If you set the record level to auto, the levels are all adjusted automatically. The manual level adjustment is covered in the manual. The levels are adjusted in pairs. Stereo 1 is adjusted the same as 2 channel. Stereo 2 needs the REC LEVEL switch of the Audio 2 controls set to M. Turn L and R dials to adjust the respective channels of the Audio 2 RCA inputs.
Jeff Donald
Carpe Diem
Old December 18th, 2003, 08:23 AM   #115
MA-200 part missing...HELP!
I recently bought a used MA-200 off of ebay.
While it is in excellent condition, the wireless microphone bracket that mounts to the back of the MA-200 was not included.
Does anyone know if this bracket can be bought separately? I have not been able to find it listed as a separate part at Canon.
Trent Robinson is offline   Reply With Quote
Old December 19th, 2003, 05:14 AM   #116
Try telephone Canon and ask (1-800-OK-CANON, navigate to parts & service).
dpalomaki@dspalomaki.com
Old February 4th, 2004, 08:50 PM   #117
attaching sennheiser evo 100 to MA200
Ok, dumb question, I'll admit it, but I'll ask it anyways.
Just picked up the sennheiser evo 100, with the camera pack. I own the MA200 as well.
Now, how the hell does the receiver plug-in, or "hold on" to the MA200.
Ok, get your laughter out.
Thank you.
Ye who asks a question remains a
fool for five minutes, ye who does not
ask a question remains a fool
forever.
Joshua Cohen is offline   Reply With Quote
Old February 5th, 2004, 05:38 AM   #118
Hi Joshua,
I attach mine two different ways, depending on whether I'm using any additional accessories or not.
If the accessory plate is not installed on the MA200, simply slide the rails on the MA200 out to the first stop and with the belt clip attached to your receiver, clip it over the horizontal piece that connects the two rails together. By moving the rail to the first stop the receiver clears the XLR connectors on the MA200. Fits perfectly and looks like it belongs there.
If I have other accessories attached to the MA200 such as CH910 or on-camera light battery, I remove the belt clip and velcro the receiver to the battery holder or accessory plate.
Just a couple of ideas that might get you started.
Ed Frazier
Ed Frazier is offline   Reply With Quote
Old February 27th, 2004, 02:52 PM   #119
Sponsor: JET DV
Broken Tab on MA-200
Anyone have the little "tab" on an MA200 that slides into the notch on the back of the XL-1 break off? Find any good ways to fix it? I'm assuming it's dangerous to just let the screw hold it on without the extra support from the tab (especially if it holds the wireless receiver). Hate to spend an extra $200 to replace the whole thing over a small broken piece of plastic.
Old February 27th, 2004, 03:01 PM   #120
Warden
I don't think the plastic tab really supports much weight, but is meant to keep the screw from loosening by not allowing the MA-200 to rotate. I would clean up the break and glue (styrene cement or epoxy) a new piece of plastic in place.
Jeff Donald
Carpe Diem
