MA-200 XLR audio adapter questions - Page 15 at DVinfo.net
Old October 11th, 2008, 07:07 AM   #211
"HOwever, if you want to go throughthe MA-100/200 Note that the MA100/200 are designed for mic-level signals, and will clip if fed a line level signal."
Actually Don, with a menu selection in the XL1S you simply select line instead of mic...I run a mixer into mine at times (just remember to switch it back : ))
G. Randy Brown is offline   Reply With Quote
Old October 13th, 2008, 04:53 PM   #212
It is the actual circuits in the MA100/200 that will start to clip if the input signal exceeds around -7 dBV, not the camcorder. While that is above nominal consumer line level (which is -10 dBV) it can be trouble for professional line levels which are more like +4 dB.
This is a hard limitation based in part on the power supply voltage.
dpalomaki@dspalomaki.com
Don Palomaki is offline   Reply
