White Balance: Episdode II - Page 2 at DVinfo.net
Old March 28th, 2002, 12:34 PM   #16
I am totally enlighted and illuminated now.
Thank you for your input Bryan!
Cheers,
Peter Koller
Vienna, Austria http://www.kop11.com
Peter Koller is offline   Reply With Quote
Old March 28th, 2002, 04:20 PM   #17
Bryan,
An 18% gray card was recommended because it is at 50 IRE's. Flesh tones are supposedly at 75 IRE's and if one were to balance to a pure white they would not look as good as a balance to the 18% grey.
a grey card is very important for exposure to find the exact zone 5 in film, im a film person, i don't work with IRE, on film you cannot measure how much it will be lit, you can only estimate, thats what the zone system is for. but for the white balance thing, 18% grey card is zone 5 so it doesn't reflect all the light it receives, you can indeed white balance with a grey card, but it doesn't reflect all the color it receives, so that is an issue. if we wouldn't care about reflectance we would try to balance the whites on a black card ! :P
but for video 18% can indeed be used. but please use filters for consistency!!!
I hope we haven't taken up too much of your time Bryan.
i will send you the bill :)
just kidding, you haven't taken too much of my time, i don't have any jobs now anyway, just boring myself, so i could as well help you guys.
C ya.
Bryan Johannes Onel is offline   Reply With Quote
Old March 28th, 2002, 04:35 PM   #18
Images: 10
pure white, black, or in between(i.e.18%gray) represents a pure luma signal without any chroma. The only difference is the amplitude or intensity of the luma signal. If you white balance against an 18% gray the camera will try to take any residual chroma out of the image. Residual chroma will come from the color temperature of the lighting. If you look at the signal of white, black or any gray in between with a vectorscope, you'll see absolutely no difference. The white balance procedure simply places the luma signal at the center of the color wheel. Using an 18% gray just keeps from oversaturating the light meter the way a white surface would, yet it gives you an accurate white balance. Just my .02 worth.
Old March 28th, 2002, 09:14 PM   #19
I just spent half an hour with my XL-1 and the gray card. The results were not much different than balancing with just a white card.
My best result was using a 1/4 CTB gel in front of the gray card and then setting white balance. The colors might have been a little bit green but I was only using the XL-1's viewfinder so I can't say for certain. I will order a 1/8 minus green and a 1/4 minus green tomorrow. When those come in I will see if I can perfect white balance with my XL-1. If I can't I will go postal.
I was hoping I could get away with just the gray card but that doesn't seem likely now. Oh well, I have learned quite a bit in the last few days thanks to all the people at this forum. Many thanks.
Greg Matty
Greg Matty is offline   Reply With Quote
Old March 29th, 2002, 07:34 AM   #20
greg
greg,
like i said, with a color temp. meter all your problems will be gone, it will just say what filter to use.
Old March 29th, 2002, 07:40 AM   #21
bill,
it will indeed place the luma signal at the center of the color wheel, but to get it balanced just right, you would need to have full color reflectance, 18% grey does not reflect all colors the way white does, white reflects all colors, with and 18% grey card you lose some of the colors if the light source is weak, pure white doesn't.
Old March 29th, 2002, 10:13 AM   #22
Re: greg
<<<-- Originally posted by bryanthedirector : greg,
like i said, with a color temp. meter all your problems will be gone, it will just say what filter to use. -->>>
Any idea what one of these thing-a-ma-jigs cost?
Also, this is for what filter to use on the camera itself correct? I would of course still need to set some sort of white balance though. Maybe just set it to white and if it is off, let the color temp meter tell me what to do?
Greg Matty
Old March 29th, 2002, 12:34 PM   #23
Re: Re: greg
900 dollar for the minolta model (best one) you should try to call minolta for some discount. here is a link to some info : http://www02.bhphotovideo.com/default.sph/FrameWork.class?FNC=ProductActivator__Aproductlist_html___35492___MICM3F___USA___CatID=904___SID=ED1 9FBB4CD0
it tells you what filter to use on the lens CC (color correction) or LB (light balancing)
no when using such a meter you need to stop thinking about white balance. this machine does everything for you.
just set your cam to 3200K or 5600K and set your color meter to that same temp.
c ya
Old March 29th, 2002, 05:53 PM   #24
to peter and john
john and peter, your welcome! :D
Old March 31st, 2002, 07:53 PM   #25
mistake
hi,
i made a mistake, lighting with film is a addictive procces, all colors mixed makes white. but still you add or substract colors.
sorry.
bye
Old April 1st, 2002, 10:25 AM   #26
RED Code Chef
Bryan,
I assume you mean additive (adding) instead of addictive? Those
are very different things. Just clarifying something.
Thanks for all the explenations!
Rob Lohman, visuar@iname.com
Old April 2nd, 2002, 12:09 AM   #27
i did mean additive rob, i guess i was in a sleepy mood.
