White Balance Issue with XL-1 - Page 2 at DVinfo.net
Old March 22nd, 2002, 07:17 AM   #16
Greg:
The Jungle Book does not have theatrical colors like the standard Rosco book, it's much slimmer and has primarily color correction and diffusion represented. Thus a theatrical supply company may not have it, but you may be able to have a film/video lighting supply house send you one.
CTO refers to the entire range of orange gels (Color Temperature Orange) for daylight to tungsten correction, and CTB to the blue gels. Thus the proper designation is 1/4 CTB, but is usually abbreviated to 1/4 blue.
As I'm sure is noted somewhere in the forum, Sony cameras tend towards the green as it increases apparent sharpness, but correcting out the green by using either a 1/8 or 1/4 green will substantially improve the skintones. This could also be done in color correction. Once you have made the correction, it is shocking to compare and realize just how green the standard Sony settings are! The Canon standard is much closer out of the box.
fargograf--yes, there are color temperature meters. Minolta makes the most popular. They provide a readout in degrees kelvin, and also designate the mired shift (which indicates how many points of magenta or green are present). It makes it easy to match all your lights to each other or the ambient light. Video is MUCH more forgiving of this sort of thing than film--it is possible to shoot under standard fluorescents supplemented with uncorrected tungsten lighting and have it look OK on tape, whereas the same scene would render noticeably green on film.
Charles Papert
www.charlespapert.com
Old March 22nd, 2002, 11:45 AM   #17
Billravens,
I just got my 18% gray card and it is very gray. I thought it would be more of an off-white but no matter, it is here.
I don't have my XL-1 in front of me right now so I can't test it to see how it works. I have always been under the impression that white balance had to be done with something close to white. Obviously that is not the case.
You mentioned adjusting a color setting by +1. Is that on the XL-1 or XL-1s?
Thanks.
Greg
Greg Matty is offline   Reply With Quote
Old March 22nd, 2002, 11:55 AM   #18
Retired DV Info Net Almunus
<< Greg: I have always been under the impression that white balance had to be done with something close to white. Obviously that is not the case. >>
Actually if you white balance against something other than a white or neutral gray you get some pretty funky results. Try it when you have some lab time.
Old March 22nd, 2002, 12:02 PM   #19
Images: 10
Greg...
yes, to our eyes, 18% gray looks dark. It, in fact, reflects no color information to the light meter...no chroma...just luma. That is, of course, unless you light it with light that has chroma in it. Shaded sunlight works good, cloudy sky light works best. Beware of lighting it with reflected light off of a colored surface. Kentanaka is right...take care when cal-ing with colored surfaces. I have great results calibrating with this card.
Yes, I've got an XL1s. 18% gray is 50 IRE...right smack in the middle of the IRE range. Calibrating with white is like calibrating at 100% IRE.....a long ways to extrapolate when reading an image that probably AVERAGES 50-75 IRE. Skin tones, for example are 75 IRE.
Good luck.
Old March 22nd, 2002, 01:37 PM   #20
<<<-- Originally posted by billravens : Greg...
Good luck. -->>>
Can you clarify the "+" setting you referred to earlier? Maybe it is an XL-1s only feature.
Greg Matty
Old March 22nd, 2002, 02:05 PM   #21
Images: 10
yep....in the XL1s there is a color adjustment in the menu. It allows shifting the recorded image chroma(hue) to red(+) or green(-). This is in addition to the "white balance, which shifts the virtual center of the color wheel....where "white" is defined.
Old March 23rd, 2002, 08:34 AM   #22
This thread has really helped on the white balance subject. How often do you white balance? Every scene or just when the lighting changes? Do you use the white balance when using a light on the camcorder?
Bob Zimmerman is offline   Reply With Quote
Old March 23rd, 2002, 01:16 PM   #23
It's best to white balance often outside if the sun goes into clouds, as the overcast sky is much bluer than direct sun. Also, at the end of the day the ambient light changes significantly--the setting sun often gets much warmer before it goes down, then the twilight is extremely blue, so if you are looking to maintain continuity then frequent white balancing will help.
When using an on-camera light, it's a good idea to have use small gels of various strengths blue and orange that will help match it to the ambient light conditions. It's an odd look to have tunsten light in the foreground and daylight in the background, but one that is frequently seen on the evening news--unless that is the desired effect!
Charles Papert
Charles Papert is offline   Reply
