shooting sunset tonight at DVinfo.net
Old August 20th, 2003, 02:19 PM   #1
I'm shooting a concert tonight from 7:00 to 9:00 p.m with the sun supposedly setting at 7:34. I am shooting into the sun and the director wants a beautiful wide shot of the sunset and the concert stage. What is the best way to shoot this, considering that the light will be changing drastically every minute? I was reading through the manual and saw the Av feature (aperture priority) and thought that this might be a good idea. Anyone have experience with this? I'm a little worried that if I shoot it completely manually, I may screw up the shot by either overexposing or underexposing. Any advice would be greatly appreciated
joshuajr is offline   Reply With Quote
Old August 20th, 2003, 02:32 PM   #2
High School Student
Shooting into the sun, with the band in front of it, will NOT turn out good, with any camera, of course unless you guys throw lots of light on the band, if you don't, either the sunset will be exposed properly, and the band will be a silhouette, or the band will be exposed properly, and the sunset will be blown out, so theres really not much you can do unless you have powerful lights, or want the silhouette look.
Other then that, shoot in manual, and just keep monitoring it, and open up the aperature more as the sun goes down...
Alex Knappenberger is offline   Reply With Quote
Old August 20th, 2003, 02:48 PM   #3
Outer Circle
Manual mode, set correct exposure for performers on the stage.
Old August 20th, 2003, 04:15 PM   #4
or maybe just do the silowhit thing at times for effect and primarly shoot the band exposed properally...thats what i would do atleast
Brian Wood is offline   Reply With Quote
Old August 21st, 2003, 06:24 AM   #5
RED Code Chef
I don't think you should compensate because you want to see
the sun fade away... Silhouttes can be quite nice. If possible
shoot a test the day earlier
Rob Lohman, visuar@iname.com
Old August 22nd, 2003, 08:50 AM   #6
Or shoot the sunset and blue-screen the band in post.
Nathan Gifford
Southern Cyclist Magazine & Productions
For quick answers try our Search!
To see me and Rob Lohman click here
Nathan Gifford is offline   Reply With Quote
Old August 22nd, 2003, 09:55 AM   #7
Try shooting at full manual. Take a meter reading at the stage and then one at the sunset. Shoot some footage with the camcorder set at the average setting. Also, bracket a few shots. I used to do this in my old 35mm days and it seemed to work. Play around with it outside BEFORE the concert to see how it will look. Bob
Bob Safay is offline   Reply
