Color noise at DVinfo.net
Old August 17th, 2003, 09:24 AM   #1
Color noise
Anytime i record with my canon xl1s i get random color noise green, red and blue. this noise is rondow and it doesn't matter the lighting condition. i use shutter 1/60 f 2.4 up to 5.6 with no change if you want to see a freeze frame in tiff go to the link
http://www.mr-art.nl/color_noise.tif
I have all the prefernces set to middle. things like sharp, color phase and so on. I have tried it with gain set to 0 db, auto, -3 and still i have this noise.
If anyone knows a solution i would be very graetfull.
Jeffrey Levenstone is offline   Reply With Quote
Old August 17th, 2003, 12:16 PM   #2
Warden
Your link doesn't work.
Jeff Donald
Carpe Diem
Old August 17th, 2003, 03:44 PM   #3
Link does work
The link does work but it is a 1mb tiff file. I used it to avoid compression artifacts. I have copy pased that link in my brouwser and the image came up.
Excuse the size of the file
Old August 17th, 2003, 05:56 PM   #4
Warden
Sorry, it comes back a 404; Requested URL not found on this server.
Jeff Donald
Carpe Diem
Old August 17th, 2003, 06:28 PM   #5
Try this one. It is a one frame mov file
http://www.mr-art.nl/color_noise.mov
Old August 17th, 2003, 08:12 PM   #6
I'm not able to view the Quicktime but the TIF file worked just fine for me. (Jeff, are you sure you weren't accidentally including the period at the end of the URL?)
Is this noise visible in the viewfinder/TV monitor, or is it only apparent after transferring the footage to your computer?
If it's your computer, this is a thread for the experts in one of the two NLE forums. If it's your camera, I'd have it sent in for service.
All the best,
Robert K S
Search DVinfo.net for quick answers | The best in the business: DVinfo.net sponsors
Robert Knecht Schmidt is offline   Reply With Quote
Old August 18th, 2003, 03:10 AM   #7
Thanks robert for the reply. And yes i see it when i play it back the monitor and TV no matter what the settings are. Do you know how reset the camera to factory default? Maybe that might help. Right now i would try anything to get this to work.
I removed the dot after the link. I thought that might be the reason.
Old August 20th, 2003, 07:32 AM   #8
RED Code Chef
Jeffrey,
You do have the s and not the plain XL1, right? Also in what
recording mode where you when you shot this? Did you have
automatic gain turned on by any chance?
What application did you use to capture this frame? [ie, what
NLE are you using?]
Rob Lohman, visuar@iname.com
Old August 24th, 2003, 06:27 AM   #9
Color noise
I have the XL1S. I used the normal mode, not the frame mode. I used -3 DB. I use http://windv.mourek.cz/ to capture. I capture to type 2 DV. I exported this from Discreet Combustion.
And i was also wondering if the is quality loss if in the future i capture thru s-video. from a technical and practical point of view.
My sitation is that i edit on a matrox digisuite le board and i need this data in mjpeg but i havent been able to use any convesion progam to achieve my goal.
Old September 9th, 2003, 09:06 AM   #10
RED Code Chef
The color noise in that picture seems to be coming from insufficient
light... Or at least it looks like that. I've seen that on my XL1s
as well. Some noise is always present, it seems...
