obvious Pixelation on black surfaces at DVinfo.net
Old March 17th, 2002, 08:54 PM   #1
The Shlook
Posts: n/a
Hi,
I have an XL-1 and when I playback footage, anything black has alot of noise in it. Just like a cheap 1 CCD camera filming in the dark.
Is it a setting I am missing or a problem with the camera?
I normally shoot with gain set to either 0 or +3.
Thanks in advance,
The Shlook
Old March 17th, 2002, 11:31 PM   #2
Retired DV Info Net Almunus
Without more information I would guess that your +3 gain is putting noise in the frame. The XL-1 tends to be a bit hot so many professionals use -3dB as their standard setting for most shots.
Old March 18th, 2002, 05:52 PM   #3
Is it a straight XL1? Or the 1S?
On the 1S, there are a lot of playful settings which can contribute. I know that with my setup, the output is sharper and more colorful but a little noisier through s-video and kind of sensitive to having the brightness set too bright.
My 1S is quite clean in the blacks. Is the rest of the pic A-OK? What about the AE compensation dial? Is that in the null position?
John Klein is offline   Reply With Quote
Old March 18th, 2002, 10:29 PM   #4
Also make sure you're not shooting in "Green Box" (easy recording) mode. Doing so will override your gain settings; even if you've dialed in -3db, it'll automatically gain up in Green Box mode.
Old March 18th, 2002, 11:21 PM   #5
The Shlook
Posts: n/a
Thanks guys,
Will look into it, and report back.
Cheers,
The Shlook
Old March 19th, 2002, 07:27 PM   #6
Also, how are you viewing it? and is the noise in all-black images or mainly in dark objects in an otherwise average lit scene?
Don Palomaki is offline   Reply
