Transfering Canon XL1s video to computer? at DVinfo.net
Old February 14th, 2008, 11:58 AM   #1
Hi! I have a Canon XL1s I haven't used in a million years, so I hope you can answer my question. We want to transfer footage to the computer using the camera as a deck. Our editing software is Windows Movie Maker -- yes, we're going ultra low rent, we're aware of that. How do I go about doing the transfer? Will WMM recognize video sent through the S-video cable? Will I need to do something else? Much thanks in advance!
-Anne
Anne Toole is offline   Reply With Quote
Old February 14th, 2008, 12:30 PM   #2
Use the firewire cable to connect the camera to the computer. Movie Maker should recognize it.
Richard Alvarez is offline   Reply With Quote
Old February 14th, 2008, 12:45 PM   #3
I don't think I have a firewire cable. What does it connect to?
Old February 14th, 2008, 04:39 PM   #4
the way to go is firewire...it connects to the firewire port on your computer. If you don't have a cable, staples/officemax carries them. If your computer doesn't have a firewire port, you wont be doing much editing.
Mike Meyerson is offline   Reply With Quote
Old February 15th, 2008, 07:48 AM   #5
As noted above, firewire is the preferred way to capture digital video and associated audio streams. You need to be sure you get a cable with the correct connector on each end. I have not used WMM, and have no info on your PC, so I don't know if it will recognize and capture from the XL1s on your PC. You might try search the forums here for any discussions on issues with WMM. I vaguely recall some folks discussing driver update issues at one time.
To use analog output from the camcorder (s-video or composite) you will need an appropriate analog capture card or device connected to the PC. There are many options available at a wide range of price points and quality - too many to list in a single post. The options range from a USB-connected break-out box, to a plug-in board, to being a built-in capability of the PC's graphics card. Many come with basic video editing software.
On getting a fire wire cable, you will probably need 6-pin to 4-pin cable, and costs range widely. You can pay from under $3 for a generic in a plastic bag to over $30 for a high end national brand name in a fancy blister pack, and for most folks the $3 will work fine.
At this point, if you want more focused suggestions please tell us about your PC. What make/model, processor and speed, how much memory, windows version, what ports it has, how many drives and size, etc.
dpalomaki@dspalomaki.com
Don Palomaki is offline   Reply
