Century wide angle converter - Page 3 at DVinfo.net
Old January 27th, 2003, 08:54 PM   #31
Hi Ryan,
Rest assured these companies are not "teaming up" and this is not a money-making scheme. The fact is that quality glass has been and always will be relatively expensive.
I've used the Century fisheye before with both lenses and I'm hoping you understand that either way you'll get serious image distortion (of course many people want that effect). However the 3x plus the fisheye is not a very useful combo in my opinion. A lot of the recordable image area is going to consist of barrel vignetting. The 16x plus fisheye is a reasonable combination but I don't think you'd like the 3x plus fisheye unless you like a big black ring around everything.
Also, keep in mind that the 3x lens at $1100 is a bargain by videography standards... most professional broadcast video lenses start at around two or three thousand dollars, and skyrocket upward from there. The Canon 3x is one of the least expensive lenses to be found. Hope this helps,
Old June 6th, 2003, 04:03 PM   #32
Century Optics .6 - Filters available?
I have just purchased a Century Optics .6x adapter; I realize that it does not thread using conventional adapter threads, but do notice threads on the front of the lens. Being the immaculate type, I'd like to know what filter-size the front threads take. Looking at the Century Optics website, I get the impression that I'd need a 95mm adapter. However, the site is unclear if the 95mm is the OD (outside diameter) or ID (inside diameter) of the lens front. Anyone know?
David Harsany Crusoe
David Crusoe is offline   Reply With Quote
Old June 9th, 2003, 02:54 PM   #33
Ok, so I talked to some people at the B&H "used equipment" department; apparently, the filter isn't a 95mm filter, but something in the 92-94mm range. Has anybody out there used a NON-Century Optics filter with their .6x wide angle adapter? Am I forced to purchase the 4x4 century optics kit?
Old June 9th, 2003, 03:48 PM   #34
I believe you're using a bayonet style adapter - If you can't attach the stock sunshade, it's a bayonet. I think the only way around that is with a mattebox, maybe someone can correct me if I'm wrong. I opted for the 3x lens instead of a bayonet adapter.
You may want to seriously consider some sort of shade with that adapter anyways. Light spill and flares really hurt a good shot :)
Andrew | Canon XL1s, ME66, Vinten Vision 3, GlideCam V16 (for sale!)
Andrew Petrie is offline   Reply With Quote
Old July 16th, 2003, 06:17 AM   #35
Hood for Century XL1s/Century Optics wide angle adapter
Looking for a hood when I use the Century wide angle adapter...where?
Mark
Mark A. Foley is offline   Reply With Quote
Old August 5th, 2003, 11:34 AM   #36
Found the hood I needed on Century's website (VS-FH44)....guess I should looked closer.....
Old October 4th, 2003, 06:36 AM   #37
Optex vs. Century Optics wide angle...
Comparing the two wide angle conversion lens for the 16X, is one higher quality than the other based on experience? Also, I know the Century is only function in Auto mode with parital zoom capability (10X for the Optex). Is that the case for the Optex?
Jeffrey
Jeffrey A. Dear is offline   Reply With Quote
Old October 7th, 2003, 02:45 AM   #38
Outer Circle
Both these adaptors were reviewed in DV Magazine - http://www.dv.com. Also, you might find some info about them at: http://www.adamwilt.com
One of our members decided on the Optex over the century, but it was for his VX2000.
Old October 31st, 2003, 05:18 PM   #39
Thickness of 72mm Century achromatic diopters?
Hi there-
I'm wondering if I can fit a Century 72mm achromatic diopter between my Xl1s lens and the port of my underwater housing. If anyone has one of these, I would be very grateful for a measurement (mm) of the thickness of the metal rim. Thank you.
Jeremy
Jeremy Monroe is offline   Reply With Quote
Old October 31st, 2003, 05:27 PM   #40
Warden
Century precision is very good with details like this. If you email or call them they will do everything they can to assist you.
Jeff Donald
Carpe Diem
Old October 31st, 2003, 11:50 PM   #41
Housing?
Jeremy,
What kind of housing are you using?
Why do you want to use diopters?
What port are you using on your housing? (Standard, Macro or Wide Angle?)
What is your subject matter?
The metal rim is not so much a factor as the magnification of your diopter. The more powerful you go, the thicker the lens will be. The containment ring should stay the same. The difference in thickness will be in the glass. This is where you will probably run into a problem as the glass will protrude farther as the magnification intensifies.
You may want to contact the housing manufacturer and ask them what the clearance is from the front of the camera's lens to the rear element of the port, or if equipped with one, the color correction filter that usually swings in between the two.
RB
"The future ain't what it used to be." Yogi Berra.
www.rbravo.com
Rick Bravo is offline   Reply With Quote
Old November 9th, 2003, 09:20 PM   #42
thanks for the info...I'll get ahold of the Century folks
Old December 14th, 2003, 02:21 PM   #43
Century 0.7 converter
hello everybody. My first post here, been reading for a while though.
First let me say that the information in this forum is absolutely wonderful and very informative. I'm foremost a record producer/engineer but with the invention of DVD the borders between audio and video production are shrinking more and more and I am getting into the video side of things. It's almost senseless to try to shop an "audio only" demo to a major label. So, I'm about to buy an XL1S in order to be able to shoot music videos and for some educational DVDs. I did have an XL1 before, which I sold right before the XL1S came out. I still have a Century Optics 0.7 wide adapter for the 16X standard lens. My question: will this converter fit on the Canon 16X manual lens?
Thank you for your help.
Michael Wagener
Double Trouble Productions, Inc.
http://www.michaelwagener.com
Michael Wagener is offline   Reply With Quote
Old December 14th, 2003, 08:30 PM   #44
Retired DV Info Net Almunus
Welcome Michael!
I do not have this converter so take my reply with a grain of salt. But, yes, if it screws onto the front of the lens then it will the 16x manual lens. Both lenses share a 72mm thread diameter.
Old December 14th, 2003, 10:43 PM   #45
.7 Century
Michael:
It wont fit, its just enough off that it wont. However if you are buying the Kit it will fit on the 16XII lens. The 16x Manual it wont however.
I found out the hard way, however thanks to Dean (I think that was who told me) another member on the board Ive found out Century will retrofit that adapter to fit the manual. I beleive he said it was about $100 to have it done.
Hope this helps
M
milking the celebrity criminal trials thank god for the freaks
Michel Brewer is offline   Reply
