Century wide angle converter - Page 2 at DVinfo.net
Old June 20th, 2002, 04:38 PM   #16
95mm
Jerry
Jerry Bixman is offline   Reply With Quote
Old June 20th, 2002, 05:23 PM   #17
Warden
The Image 2000 matte box is a good choice http://www.birnsandsawyer.com/index.asp . Its made for the Century adapters (95mm) and not too expensive. I see them on ebay ocassionaly for around $250, but as always, buyer beware.
Jeff
Old June 21st, 2002, 01:25 AM   #18
Thank you for your suggestion Jeff.
Jerry
Jerry Bixman
Innlight Video Productions
Old August 16th, 2002, 12:13 PM   #19
Warden
What Century Precision Adapter fits what lens?
Century Precision Optical has a new series of charts on their site that explain in detail what adapters ( including Century part numbers) fit what lenses and hoods. http://www.centuryoptics.com/products/prodv/xl1/chart.htm
Jeff
Old August 16th, 2002, 03:31 PM   #20
Very handy... many thanks, Jeff.
Old August 23rd, 2002, 10:32 AM   #21
ChorizoSmells
I have a .7X wide adapter for my 16X lens for the XL-1. Also just got off the phone with Chris over at ZGC, ordered the fisheye adapter. The people at ZGC rock, I'll have the fisheye adapter by next friday(30th). Can't wait to shoot with it. Now my friend with an XL-1s can use one adapter, and I can use the other on two camera shoots!
ChorizoSmells Video
Barrio Tamatsukuri, Osaka, JAPAN
Rik Sanchez is offline   Reply With Quote
Old October 10th, 2002, 11:31 PM   #22
Slash Rules!
Century .6x converter and manual 16x lens
Here I am once again trying to find out how to use a piece of equipment that I've ordered. Just got my Century .6x zoom through converter, made for the manual lens. I checked with the lovely (I'm assuming) Chris from ZGC before ordering, and she verified that you can indeed zoom through with the converter on the manual lens, even though descriptions I have seen of the .6x say that you have 8x zoom "with autofocus only."
I put this thing on, and find that at it's widest setting, it's blurry with the iris opened all the way up. I adjusted the back focus, and now it's fine. That's only at the widest setting, however. Once you start to zoom (sorry I didn't take note of the factor) a litte bit, it goes blurry. Now, if it's got 8x zoom, that means it should be in focus through half of the manual lens's zoom range, no? The regular focus ring seems to have no effect when the converter's on, regardless of focal length.
Can anyone help?
Old October 11th, 2002, 01:22 AM   #23
Warden
The back focus is not adjusted properly. Adjusting the back focus may take a little experimentation with the converter. My guess is that you'll need to set the back focus at the 8X position first. Then zoom to the widest setting. Trial and error will get you there. Also make sure you're focusing on something far enough away when our setting back focus.
Jeff
Old October 11th, 2002, 01:33 AM   #24
Once you have your back focus set, don't even think about touching it again.
Old October 11th, 2002, 06:37 AM   #25
Slash Rules!
Jeff, if I set it at the 8x setting. . .won't I be blurry at the widest setting?
Old October 11th, 2002, 08:36 AM   #26
Warden
I'm not sure. But if it wasn't getting it before, I can't figure how else it might work. You could always call Chris at ZGC and ask. When setting the back focus are you focusing on an object far away? It should be something far away (200 yards at least) not the mail box at the end of the drive.
Jeff
Old October 11th, 2002, 03:38 PM   #27
Slash Rules!
I haven't focused on anything too far away. I can try it. I thought the idea behind the back focus was that it adjusted the focus at the lens's widest setting, and on the XL1s, in my experience, that means everythings in focus anyway, near and far (except when exceeds the minimum focus range for the manual lens).
Old October 11th, 2002, 07:15 PM   #28
Warden
Here's a link to adjusting back focus.
http://www.videouniversity.com/backfoc.htm
They suggest an object at least 75 feet. My experience is that is not far enough. But it may be OK for 1/3 inch chips and a WA adapter. DOF will cover small errors.
Jeff
Old October 12th, 2002, 12:15 AM   #29
Slash Rules!
Jeff, thanks. Here is what your link said (I'm posting it so what I write afterward will makes sense).
1.Set the iris to manual.
2.Set the zoom to manual.
3. Open the iris to 1.4 or its widest aperature. If the illumination on the test chart is too bright for the open iris, reduce the light or move the chart to a darker area.
4.Turn the zoom barrel to extreme telephoto.
5.Focus on the chart.
6.Set the zoom to wide angle.
7.Loosen the back focus ring retaining knob.
8.Adjust the back focus ring for the sharpest focus.
9.Repeat steps 4 through 8 until focus is consistently sharp.
10.When it is, tighten the back focus ring
retaining knob to secure the ring.
This is exactly how I've been doing it, with the exception of cheating on the distances of my obects upon which I focus. I've never had a problem maintaing consistent focus before.
I talke to Mizell at ZGC about this today, and he gave me a variation on the above formula.
He said instead of going all the way to wide angle, as in step 6, you're supposed to slowly zoom out from telephoto only until the image gets blurry, and then adjust the back focus ring again, and continue to do that until the image is sharp throughout. He said it usually takes 5 or 6 adjustments. Has anyone heard this? I've always done it just once the above-mentioned way, and never had a problem with focus.
Old January 27th, 2003, 07:55 PM   #30
A little confused about the Century Optics Fisheye for the XL1S...
On the site it says with the stock 16x lens you can only get a 85 degreee horizontal view, but with the 3x lens you can get 116 degree horizontal view.
So does this mean that I will have to buy the 1000+ dollar 3x lens to get the widest field of vision with the lens?
Seems like some sort of money making scheme Canon and Century teamed up on...
Ryan Krga
Ryan Krga is offline   Reply
