XL1s sharp or soft shooting? at DVinfo.net
Old December 3rd, 2007, 06:48 PM   #1
which is better for compositing, in camera setup, full sharpness or minimum?
Austen Mathieson is offline   Reply With Quote
Old December 4th, 2007, 08:54 AM   #2
Images: 10
all the sharpening applied is in-camera modification of the basic image. there's no reason, I can see, to add sharpening in the camera. add it, if you feel you need it, in post.
Old December 4th, 2007, 08:47 PM   #3
I've been using the cam with the sharpness fully off/down to get the softer film look but it causes probs in compositing. I thought maybe sharpness or sharper pixels might make it better/easier to composite at the edges. Just a thought.
Old December 4th, 2007, 10:50 PM   #4
always sharpness off, edge enhancement can be added later if you want it, it can never be taken away once there as it drastically alters high contrast edges by darkening the one side and lightening the other side to accentuate the contrast edge.
Web Youtube Facebook
Cole McDonald is offline   Reply
