Maintaining and Cleaning my xl-1
I have been reading that you should stick to one type of tape or another. Unfortuently, I've been using Panasonics, TDK and Sony. Is there a procedure I can do to clean the heads of my xl? And do the heads need realligned like the heads on a DAT at certain intervols? Thanks in advance for any advice.............
Bryan Coleman
Bryan Coleman Santa Cruz CA |
Retired DV Info Net Almunus
Get and use a miniDV cleaning tape. If you use your camera reasonably heavily and/or professionally it's a good idea to send it to Canon service for a routine cleaning and calibration each year.
Lady X Films: A lady with a boring wardrobe...and a global mission. Hey, you don't have enough stuff! Buy with confidence from our sponsors. Hand-picked as the best in the business...Really! See some of my work one frame at a time: www.KenTanaka.com |
Maintenance procedures (including head cleaning) are on pages 66-67 of the (NTSC) manual. Sony- and other-brand dry MiniDV cleaning tapes will work OK too.
Because the cleaning process causes aditional wear, Canon suggests do it only when indicated. A tape brand change after a steady diet of another brand is a good time. Frequent changes of tape brands might not require cleaning as often.
dpalomaki@dspalomaki.com |
Now that you are sticking to one brand of tape that will help. Sending the camera in once a year for maintenance is also a good idea (it will at least keep the heads aligned).
If you haven't been using 4-track, you can also use any cheap miniDV as a playback deck for those other tapes.
Nathan Gifford Southern Cyclist Magazine & Productions For quick answers try our Search! To see me and Rob Lohman click here |
