adapter to hook a radio mike to RCA jacks at DVinfo.net
Old May 23rd, 2003, 09:00 PM   #1
Hello -
We have an Audio Tecnica radio mike. The mike part is ATW-T101 transmitter.
We want to hook it up to two (L and R) RCA female outputs. The transmitter has a kind of hole with five pins in it.
What is that thing called? If I can't name it, I can't ask for the correct adapter!
Thanks for any help.
Jane Regan is offline   Reply With Quote
Old May 23rd, 2003, 10:13 PM   #2
Retired DV Info Net Almunus
Jane,
The transmitter connects to a lav mic which plugs into that 5-pin mini-XLR connection.
Do you mean you want to connect the RECEIVER to a left and right channel at the camera?
Old May 24th, 2003, 07:34 AM   #3
Or are you attempting to feed the wireless transmitter with audio from something with stereo RCA jack outputs?
dpalomaki@dspalomaki.com
Old May 24th, 2003, 08:16 AM   #4
Ken, I want to connect the transmitter to the RCA outs of a mixing board, so that me, my camera, and my receiver can be recording a musical group far away from the board. Does this make sense?
Jane
PS So, is that little thing called "mini XLR" then?
Old May 24th, 2003, 10:32 AM   #5
Jane,
According to Audio-Technica's page on their 100-series systems, you need a...
AT8340 - Input cable connects mics with 3-pin XLRM-type output to ATW-T101(x) body-pack transmitter. 4.3' (1.3 m), XLRF to TA5F connectors.
Looks like they call it a TA5 connector.
Old May 24th, 2003, 11:04 AM   #6
Per the on-line manual, shown at http://www.audio-technica.com/prodpro/addinfo/U100Ser_OM.pdf, The ATW-T101(x) body-pack transmitter has an industry standard TB5M input connector with both low- and high- impedance inputs plus a bias connection.
It also appears to support both mic and line level inputs. If using line level output form the mixing board (likely if RCA jacks) you may need to have a special cable made up. Level adjustmetn is covered in the manual.
This is discussed somewhat in the manual, but is not totally obvious to lay-people. If it is not clear, find a local technician to help, and buy his/her favorite beverage as a reward (unless you have to otherwise pay for the support).
Don Palomaki is offline   Reply
