best compression to share H1 footage
as compression like wmv muds the heck out of such lovely footage, what would you guys recommend using to make videos to share from the H1. I do have sorensen squeeze 4 so i have alot of choices...
Cinematography Site |
H264 I have had luck with, especially for HD.
-brian Warwick! I'm a Johnson & Wales alum |
Where would I find that codec? And how would I compress to it? And what did you graduate with? Something in the food industry I would guess? Small world ;)
If you're working with FCP then you can make H264 (QT) files with both the export function and Compressor. My vote goes to H264 as well by the way.
#5 |
Final cut export will get you what you want. Also Quicktime Pro export will work.
I actually graduated from the JWU school of technology with a web degree, then transfered to University of California for my film degree. |
#6 |
Oops my mistake :D Well I`m using a PC actually with Premiere Pro 2.0, but i did finally find the export option, I didn`t know it was a quicktime thing, thanks guys :) So anyone with QT will be able to view it right? Any suggestions on the dimensions, compression settings etc?Its a quick 2 minute demo
#7 |
It depends on your source format and the average bandwidth of your client.
If its DV 720x480, you can keep that resolution with H264 and limit to 600-700kbps. This will work on average for DSL and cable subscribers. If its not quite forking for you, take the resolution down a bit. Keep your aspect ratio correct though. Make sure you deinterlace. Make the audio 128kbps. Keep your framerate. Anyone with quicktime 7 or better can view H264. I wouldnt recommend delivering in HD resolutions. Most computers over a year or so old cant process H264 HD. http://www.apple.com/quicktime/techn.../h264/faq.html |
#8 |
well i just want to share it here. For general feedback and "oooo look at H1 footage', but i don`t want to lose the visual quality of it. Its 1440x1080. Its only being posted here and a few other forums, nothing big. Like Steven Dempsy I believe put up a few H1 videos like that....wondering if he could chime in?
#9 |
I tried using premieres Media Encoder with QT h264. However it won`t let me resize it, i tried exporting at half size (720x540) and it just shrinks the frame you can see, not the actual video. What did everyone else use thats posted video from the H1?
*EDIT* Ok so the built in Adobe Media Encoder sucks. I used 'export movie' with the same settings and the video look as it should, no glitches, no jumpiness (aside my shaky hand ;) ). While it seems only a temporary solution to the problem because exporting uncompressed to make flv later on won`t work, it works for the time being and what I need at this moment in time *edit again* H264 while works, makes it look pale color wise, i tried planar RGB which looked stellar until i saw the file size. Ugh.
Cinematography Site Last edited by Nathan Quattrini; February 23rd, 2007 at 01:56 PM. |
#10 |
solution
Nathan / Try Mpeg Streamclip freeware for pc and mac / accept m2t /
cineform avi / converts to mpeg 4 / quiktime / and avi with all the popular codecs onboard. Easy to use / Great results. Peace / Herman |
