XLH1 Sony incompatibility at DVinfo.net
Old February 7th, 2007, 06:49 PM   #1
Not sure if this has come up before. I'm aware of the 25F issues but this is regarding 50i.
Had an issue with HDV 1080/50i tapes from a PAL XLH1 not playing back properly in Sony decks.
Spoke to Canon Australia, apparently there is no 'official' head alignment standard across manufacturers, I'd assume they have their own internal standards. Canon Service can align heads to a Sony deck standard as a service procedure.
Frustrating that they don't try to do this out of the box, especially as Sony decks are so commonplace and Canon don't even make a true playback deck.
Why there isn't a common alignment standard is also a mystery. Given Sony's position in the marketplace, at least in Australia, this should really become the default standard. Defeats the purpose of having a common 1080/50i standard to begin with.
Don't know if anyone across the pond has come across this in 60i land, but something to be aware of as a possible, not definite, problem if you normally use your XLH1 as the feed deck but then have to give over camera tapes for ingest somewhere else.
Rich Kickbush is offline   Reply With Quote
Old February 7th, 2007, 09:44 PM   #2
Got a HDV 60i tape from a friend the other day shot on a Sony and it played fine in my XLH1.
I think it is more of a format issue than an alignment issue.
Mike
Chapter one, line one. The BH.
Mike Teutsch is offline   Reply With Quote
Old February 8th, 2007, 02:32 AM   #3
Hi. If you see my thread in the long thin line forum (got moved from this one for some reason) I am havig prolems here in the UK with the H1 and the Sony hvr m10 deck .The camera is now back with Canon to check out ,up to three weeks they estimate the time they need. Twice I sent the deck to Sony three day turn around on both occasions. Canon need to get their support here for this level of eqipment sorted out. Not a patch on Sony support.
I will let you know the out come when the camera returned.
Regards
Mick
Mick Jenner is offline   Reply With Quote
Old February 8th, 2007, 08:25 AM   #4
All topics concerning tape and VTRs go to The Long Thin Line. That's why we moved it. Hope this helps,
Old February 8th, 2007, 08:51 AM   #5
Spoke to a Sony tech today - Sony send out alignment tapes to all their service people which in a perfect world means that all Sony decks are aligned the same.
Guessing now but possibly Canon are using a different alignment standard, or reference, or tape to set up their H1's, and the rest of their cameras, if they are selling the idea of using HV10/20's as 'feeder decks'.
Or are Sony's more fussy with their alignment? I've heard before that tapes shot in Sonys will play fine in the H1...but the problem seems to be going the other way.
Gotta wonder what is the point of having an HDV standard at all if everyone is going to do their own thing anyway. I'm guessing Sony wouldn't be handing out their alignment tapes to Canon but seeing as how Sony had established themselves in the HDV marketplace first with the Z1 (no, I don't count JVC's first abomination as a contender) it would have been prudent for Canon to do some reverse engineering and follow suit. Its only going to hurt their sales if people aren't able to simply take their 50i tapes into any post house and know that they will play on their Sony decks...
Does anyone from Canon lurk on this board?
Would love to hear their thoughts if so...
Old February 8th, 2007, 09:04 AM   #6
Yes. That's exactly what they're selling.
There are actually three different HDV standards, and they're all pretty much incompatible with each other. JVC has what we commonly refer to as HDV1, which is the 720p flavor, and Sony has HDV2, which is the 1080i60 flavor. And then Canon has a version of 1080i called Frame mode which provides 1080p30 and 1080p24, which is not compatible with Sony HDV VTRs.
I run the site with largest HDV presence on the internet, and I'll be the first to say that it's definitely a less-than-ideal situation. Bring on the tapeless formats! Until then, all of us will have to work around the incompatibilities (by using Canon consumer HDV cams as feeder decks, and other interim solutions).
Old February 8th, 2007, 09:29 AM   #7
Thanks for the info Chris,
But reading from previous posts on the Sony/Canon compatability on this forum it does seem there is a fix when recording in 60i and 50i. I am aware that you cannot play back in 24 or 30 mode or in our case 25f mode. Any way I will up date on the cameras return (when ever that will be).
Mike,
All my tapes recorded on the Z1 play back fine on the Canon and nearly all the tapes recorded on the Canon play fine on the Sony. Its just the odd tape that some how hangs and drops frames even though it play perfectly on the Canon
Many thanks
Mick
Old February 8th, 2007, 09:29 AM   #8
Does anyone know why Canon does not want to either manufacture their own VTR with robust editing tape drive or brand name another VTR maker's Canon spec'ed unit?
Surely seems like there is a sizeable market for it ...
John Richard is offline   Reply With Quote
Old February 8th, 2007, 05:25 PM   #9
Your Canon XLH1 should be compatible in all DV formats and 50i HDV with Sony. If it isn't then they should fix it or replace. They did fix mine for a similar NTSC issue. Sometimes things slip up at manufacturing and this is one of the results. Most people don't test compatibility with other gear when they first get a camera. This is one of my basic tests for a new camera.
DV needs a tracking knob is what I have decided. I have a Sony DV alignment tape which never seemed to be sensitive enough to insure the GVD-900 I played it on would record a properly aligned signal. It would get me close but not perfect. Usually you would get the adjustment after a few tries even though the alignment tape said it was fine the first time. I don't know if the Canon has an easy adjustment for their cameras so it might not be as easy for them to fix.
Old February 8th, 2007, 05:29 PM   #10
Money-------It would not be profitable. Why not just sell cameras that work as decks? More customers for the same product!
Mike
Old February 8th, 2007, 07:55 PM   #11
Agreed. I don't think you'll ever see an HDV VTR from Canon.
Old February 9th, 2007, 11:05 AM   #12
Chris;
Just to be painfully clear. Both the HV10 and HV20 will play 24f and 30f XL H1 tapes? The HV20 specs refer to a 24p mode, 24f with a consumer friendly name? Thanks.
Walk in the light.
www.barrygregg.us
Barry Gregg is offline   Reply With Quote
Old February 9th, 2007, 11:20 AM   #13
Hi Barry, no problem being painfully clear: both the HV10 and HV20 will play tapes recorded in 24F and 30F from the XL H1 and XH series camcorders.
The 24p in the HV20 is *not* Canon's Frame mode, so no it is not 24F with a consumer friendly name. You can read more about this in my article at http://www.hdvinfo.net/articles/canon/hv20overview.php -- hope this helps,
Old February 9th, 2007, 01:13 PM   #14
So do we know for sure if the new "24p" mode of the HV20 will be compatible to playback on standard HDV devices? Or at least HDV type2 devices? If I put a 24P HDV recording from the HV20 into my XLh1 will it simply play it as a 60i HDV stream with 3:2 pulldown embedded? Or is that question something that has not yet been given a clear answer?
Marty Hudzik is offline   Reply With Quote
Old February 9th, 2007, 01:41 PM   #15
Yes. It's important to realize that 24P is recorded to tape as a 60i signal -- it has to be -- and therefore it's transparent to the playback device. That is, anything that can handle 1080i60 playback will also be able to show 24P from this camcorder.
Chris Hurd is offline   Reply
