Balck and White Video at DVinfo.net
Old December 1st, 2006, 09:08 AM   #1
Originally Posted by Steve Rosen
Sure, if you can use the XL2's 16x manual on the H1 (which I do regularly) then the 20x will work fine on previous XL models... You will probably have to set the back focus manually though...
The 20x, although awkward to manually focus, is a pretty nice lens - some CA, which has been talked about often here, but not as bad as you might think from some of the posts - I just finished a commercial in SD that will be distributed nationally to Rape Crisis centers - I shot with the 20x in B&W and it is really pretty stunning. I was surprised at how good it looked (B&W often looks like crap in video).
Hi Steve.
Did you set up the camera to shoot B/W or correct in post. If the former, I would be interested to know your settings.
A.
Alistair Briggs is offline   Reply With Quote
Old December 1st, 2006, 09:24 AM   #2
Split out as a separate topic from the "H1 lens backwards compatible?" thread.
Chris Hurd is offline   Reply
