#16 |
OK. Here it is. I've done the back focus, pictures is frame grabs.
Barrel distorion; Chart and some shots done at my studio. Resolution Charts; at full wide and full tele. Depth of field; with help from my assistent Linda, one at full wide and one at full tele (shot with Schneider Black Frost 1/2).
Jonas Nyström, DoP :: HOT SHOT® SWEDEN :: www.hotshot.nu :: RED #1567, RED 18-50mm T3 :: XL A1, Letus Extreme :: XL H1, 20X & 6X lens (for sale) :: www.vimeo.com/nystrom |
#17 |
And here is one more on barrel distortion and one pic on the 6X mounted on the H1 with rod system. For gear ring (follow focus) we will need a gear ring with 34 cm circumference.
#18 |
Thanks for the shots and info, Jonas. If you could possibly do a small selection of test photos at outdoor locations sometime in the future, it would also provide much-needed added information on this interesting lens.
#19 |
Some exteriors shot with the new wide (stills). All shot at full wide. Have a look at the low barrel distortion, extreme long DOF and the angles.
I love the manual iris ring!
#20 | |
and push exposure lock like it says to do the iris ring still does nothing. Am I missing something? thanks
will griffith producer/editor |
#21 | |
I donot have lens but I have ask if you flashed the bios on your camera when you got the lens? I do not think the iris ring will work unless you do this first. Good Luck. I sure hope it is something like this and not a defect. |
#22 |
Exactly, you must update your camera firmware (included).
#23 |
Hmmmmm....
It is already at 1.0.3.0 (new body only kit). I will email Canon and see what hey say. thanks
#24 |
BTW....
Here is an uncompressed 10bit 1080p frame grab w/6x lens. I like this camera. :) I will post a :60 spot we shot on monday sometime this week.
#25 |
Thanks for the exteriors Jonas.
There seems to be slight colour fringing/chromatic aberrations in places, although probably not so noticeable in a moving image. Can you remember the f/stop settings for each of the exterior shots shown? It would be nice to view a side-by-side test between the XL 3XSD and 6XHD lenses to see how much of an improvement has been made with new lens - in both perfomance and handling. |
#26 | |
Sorry, I did the exteriors in a rush, and did not make notes of the f-stops!
#27 | |
#28 | |
#29 |
Found it. :) didn't see it when I first opened the box.
That's what happens when you can't wait to play with a new toy. thanks
#30 |
It's easy to miss...especially if you are tossing things out quickly to get to the lens :)
It is with a 3" by 4" folded piece of paper in a plastic sleeve. -will
