Underwater Housing help on H1 at DVinfo.net
Old November 2nd, 2006, 08:09 AM   #1
Thanks anyone for great help!
I had a Xl2 and I am planning to get my H1.
I need to use it underwater. Now I am on a Gates, specificaly for Xl2 (4000 USD).
These days I discovered that Canon H1 wil not fit Gates Xl2 housing even they are almost the same size (the H1 is 1 millimiter taller).
Using the Xl2 inside Gates housing the shoulder pad a the viewfinder need to be removed: no problem because it has some screws...
Canon support can't help me about removing the shoulder pad on the H1: "it could be removed but we do not suggest to do it because some electricalcomponents...".
The new Gates H1 Housing will get around 9000 USD.
So I really would use my old one (for XL2).
The question is:
Is it possibile to remove the shoulder pad on the H1 without damaging the camera? I will not use the output at 1.5 gbits, so...
Anyone of you know if is possible cut off some cables inside the shoulderpad without compromising...
Thanks for help, Gabriele
Me and Canon
Gabriele Ferri is offline   Reply
