SteadyCam and Manfrotto FigRig at DVinfo.net
Old September 22nd, 2006, 01:44 AM   #1
Hi,
I'm evaluating some steadycams for my XL-H1, Manfrotto has come out with a new system called FigRig, it has been developed by Mike Figgis. Do you know anything about it? Which are the best steadycam solutions for the XL-H1? Will they actually remove the vibrations?
Thanks a lot for your response
Christian Bertolini is offline
Old September 22nd, 2006, 03:11 AM   #2
This topic would be better suited in the camera support section here: http://www.dvinfo.net/conf/forumdisplay.php?f=42
Take a look around there for camera support and stabilization options.
The Fig Rig is not even close to a Steadicam, nore does it try to be. It's a camera grip, not a stabilizer. The best Stabilizers costs thousands of dollars but prodcuce perfectly stable shots with no vibrations or shaking.
- Mikko
Mikko Wilson - Steadicam Owner / Operator - Juneau, Alaska, USA
+1 (907) 321-8387 - mikkowilson@hotmail.com - www.mikkowilson.com
Mikko Wilson is offline
Old September 22nd, 2006, 05:47 AM   #3
Thanks for the info Mikko, this just confirm my impression.
Cheers
Christian Bertolini - Producer
Melbourne, Australia - www.i-pumpkin.com
Old September 22nd, 2006, 06:27 AM   #4
And neither is the FigRig a new product. It has been around for a while now and is aimed squarely at hand-held camcorders and not meant to be used with shoulder-cams (or similar).
Chris Wren is offline
Old September 22nd, 2006, 07:42 AM   #5
Normally this topic gets moved to Support Your Local Camera, but this time I'll leave it here. Closed in order to encourage the discussion to move to SYLC at http://www.dvinfo.net/conf/forumdisplay.php?f=42
Chris Hurd is offline
