I have IEEE issues. at DVinfo.net
Old August 28th, 2006, 07:51 PM   #1
I have IEEE issues.
I have the new Canon Hi Def camera and have been able to hook it directly through my IEEE connecter to my notebook. All worked fine.
Now, suddenly though, when I connect the two, nothing happens. Preimier can't see the device, nor does DV RACK. I also can't see the device in the system folder. Anyone know of any issues? Did I accidently flip the wrong switch? Help!
Marty Molloy is offline   Reply With Quote
Old August 28th, 2006, 11:08 PM   #2
Help! I have IEEE issues.....Any ideas?
Now, suddenly though, when I connect the two, nothing happens. Preimier can't see the device, nor does DV RACK. I also can't see the device in the system folder. Anyone know of any issues? Did I accidently flip the wrong switch? Help! I've gone through the manual a couple of times and I'm missing something.....
Old August 29th, 2006, 06:22 AM   #3
First things first: replace your Fireware cable - I have already thrown one away.
Ervin Farkas
www.AtlantaLegalVideo.com
Old August 29th, 2006, 06:43 AM   #4
Marty,
There is a menu item to turn on the ieee port so it is possible to have turned it off. Also you should turn the port on before you connect the camera. This could be your problem. Check out Page 113 of the manual. Signal Set Up
Old August 29th, 2006, 09:15 AM   #5
Ok, thanks....I forgot to say that we've determined that the firewire cable is good, any other ideas?
Old August 29th, 2006, 09:20 AM   #6
Which Canon camera is this? Specific model number please.
Old August 29th, 2006, 02:47 PM   #7
Xl-h1...;-)
Old August 29th, 2006, 04:27 PM   #8
Moved from Open DV Discussion to our XL H1 forum.
Old August 29th, 2006, 05:20 PM   #9
Having had the same problem with IEEE, it was determined that my IEEE port in the H1 had a pin that was broken off by a defective cable input (new cable that came with a Firestore).
Suggest you do what the service rep at the Canon Factory Service desk did;
Take a pin flash light and magnifying glass and inspect your H1 firewire jack for bent or broken pins.
And I highly recommend Canon Factory Service (at least their Irvine, CA center) - they were top notch - 1 day repair that saved my tail.
John Richard is offline   Reply With Quote
Old August 29th, 2006, 06:24 PM   #10
Hi Chris. Now we have a duplicated post. :)
Richard
Richard Hunter is offline   Reply With Quote
Old August 31st, 2006, 01:51 PM   #11
Thanks guys!
