More than one test bar to H1
Hi,
I got idea that I could put more test bars as jpg images to memory card. Then just play them back and adjust monitor and EVF. H1 didn't playback my images. Does anybody know how to prepare external images so H1 could play them back? I did take pic with H1 and in Photoshop I did put test pic top of it, flatten image and save. That didn't work. Harri |
The manual states that images created on a computer, or other source, will not work in the XL-H1.
Sorry, but I do not know what format to use to create an image that will work.
Dan Keaton Augusta Georgia |
#3 | |
-gb- |
Agreed.
There is no telling how the camera would playback the image and if the images would be produced correctly. I would stick with color bars in the camera and take your calibration cards with you in the field (if your really worried about being that exact every time) Depends on your shooting style. |
#5 | |
- Ed Moore DP |
#6 |
Ed,
I think you are experiencing a difference between the Pal and NTSC version of the camera. The NTSC H1 manual states the camera produces Smpte bars. What does the Pal manual state? Full field bars (the kind you seem to have) are more common as a european standard from the late 80's and early nineties. As an example I used to have NTSC Philips BTS cameras and the early versions had full field bars even though NTSC Sony and Ikegami cameras came with Smpte bars for the US. Our complaints were similar to yours. Some cameras also give you your choice of bars to be displayed. |
#7 |
Ed,
I'm not sure what your souce is but the H1 DOES output SMTPE bars with PLUGE. Manual quote "You can generate and record SMPTE (Society of Motion Picture and Television Engineers) color bars." - pg 93 It also produces a 1k tone with -12 or -20db selectable. I just powered mine up with a monitor, PLUGE is easily visable. --edit-- sorry for the repeat, i think Daniel & I were typing at the same time. |
#8 |
No worries Brian, as it is well worth stating two or even three times:
The XL H1 does in fact output SMPTE color bars. Thanks, |
#9 |
Sorry to contradict such esteemed company, but I am sitting with my H1 right now and all I get are 75% EBU bars.
As mine's a PAL H1 I can only assume that Canon have very irritatingly chosen to replace the SMPTE bars with the EBU for the European region. Any ideas if there is some secret menu that will get me SMPTE back? Actually - could this be an issue with SMPTE licensing outside the US? Cheers, Ed
- Ed Moore DP |
#10 |
Hi Ed,
Here's how it works. On the XL H1, the color bars go with the region. If you own the North American / NTSC version then you have SMPTE color bars. If you own the Eurpean / PAL version then you have EBU color bars. If you purchase the 50i/60i system upgrade from Canon, then you have both versions. In other words if you have a 60i camera and you want the EBU color bars then you have to buy the 50i upgrade. Same thing for 50i camera owners. If you want the SMPTE color bars then you have to buy the 60i upgrade. Even then, the SMPTE color bars are visible only when recording in 60i mode (and EBU color bars only when recording in 50i mode). Hope this helps, |
