#16 | |
BTW, I would think that the monitor would be near impossible (or just plain impossible) to use when shoulder mounted. Is it just limited to tripod/dollies or is there a way to extend a mount so it's not right in your face. Ken
C100, 5DMk2, FCPX |
#17 |
Rob, what type of battery life would you get with a normal Canon BP945?
Kevin |
#18 |
Rob I have a marshall HD-SDI monitor that I would love to purchase the canon mount for do you guys sell the mount only?
I have a dream that one day canon will release a 35mm ef to xl adapter and I'll have iris control and a 35mm dof of all my ef lenses, and it will be awesome... |
#19 |
Another question for Rob: Which Sony batteries can be used with the Nebtek modification? Do the Sony M series work as well?
#20 |
NEBTEK
Hello Everyone,
In answer to all of your questions.... "what type of battery life would you get with a normal Canon BP945?" Battery life on a BP-945 is about 2.5 to 3.5 hours continually running. "do you guys sell the mount only?" We can not sell the mount alone since we wire the unit internally in order to make it swappable with the IDX plate. The modification must be done at NEBTEK or you warranty is voided (NEBTEK assumes the balance of your warranty once the procedure is done). Cost- $210, Turnaround time- generally 1 to 2 days. "Do the Sony M series work as well?" Our SONY Li Battery adapter works with either the SONY L or M series batteries. And Yes KEN... HD does mean "High Debt" when it comes to buying the right gear for your camera. Our initial investment on the SONY Z1U is now well over $10K with everything we supply in the rental kit. Keep you friends close and your wallets closer everyone... the toys just keep getting better and better, -Rob:)
Robz |
#21 |
Just wanted to post that I've received my marshall monitor back from Rob DuBree at Nebtek and it's steller. The ability to now use Canon batteries is *almost* priceless I absolutely reccomend this to anyone that doesn't want to use IDX or V-Mount batteries with thier marshall monitors.
