Ghosting and Trailing Images at DVinfo.net
Old June 9th, 2006, 11:42 PM   #1
Has anyone had ghosting and trailing after imageing while shooting with the Canon XL H1 in the 24F mode.
Bob Nielsen is offline   Reply With Quote
Old June 10th, 2006, 02:25 AM   #2
I belive u need to turn off the "Denoiser" function in the menus
it has been discussed in these forums as i remember
Lior Molcho is offline   Reply With Quote
Old June 10th, 2006, 11:10 AM   #3
Are you referring to the ghosting in the viewfinder? This is a viewfinder artifact and isn't recorded to tape.
Or, you may be referring to the ghosting that happens when you downconvert with the camera and play via the analog video out on an NTSC TV. This also is an artifact that is a result (presumably) of the processor-intensive in-camera downconversion and telecine process, and is not recorded to tape. Just hit pause to freeze a frame and you'll see there are no trails.
Gabriel Fleming is offline   Reply With Quote
Old June 10th, 2006, 02:08 PM   #4
Disjecta
This problem is also associated with having "NR1" turned on in your preset. Turn it off and if you need noise reduction, use NR2 instead. This trailing is a known side effect of NR1.
Try my Digital Therapy: http://www.pinelakefilms.com/digital_therapy.html
Films on ExposureRoom: http://exposureroom.com/members/disjecta.aspx/videos/
Steven Dempsey is offline   Reply With Quote
Old June 11th, 2006, 11:51 AM   #5
NR1 is really for interviews and camera lock down shots...
ash =o)
Ash Greyson is offline   Reply
