XL H1 and decklink at DVinfo.net
Old May 19th, 2006, 03:33 AM   #1
XL H1 and decklink
HI,
I'd like to use my new XL H1 with the Decklink HD Extreme and I have some Question. I use it for film and I use the camera in my studio. My monitor has Component-Devices.
Can I see the live-editing, Photoshop, Keying ... only at the SDI_Out or also at the Component-Out?
Do you know a trick how can I use the keying video at my PP 2.0?
Peter
Peter Walter is offline   Reply With Quote
Old May 21st, 2006, 12:27 AM   #2
OkI'm Trying to capture from the XL H1, still doesnt want to work,
Now I installed Premiere Pro 2.0, Cineform HDV and connecto to another Firewire port, still the same thing, now in the camcorder the device control is OFF and in the Premiere Capture window the Device control is on Cinefrom HDV Device Control, I can control the camera from the Premiere but when I play6 it, I cant get nothing on the capture screen.
THe Capture Format is set to CineForm HDV Capture,
Do you have any Idea what I'm doing wrong?
Nerses Papoyan is offline   Reply With Quote
Old May 21st, 2006, 10:01 AM   #3
Are you able to capture with HDLink?
Best,
Christopher
Christopher Glaeser is offline   Reply With Quote
Old May 21st, 2006, 02:09 PM   #4
Do you select Downsampling HD to SD. If you can use it with DV you have switch on these on the camera.
Peter
Old May 22nd, 2006, 11:38 PM   #5
I did
I did capture with HDlink an M2T files, then convert them to AVI, but I dont know what setting in conf I should use to get the best quality .
Then in Premiere pro 2.0 I'm still not able to capture./
Any sugestions?
thank you in advance
Old May 23rd, 2006, 12:31 AM   #6
Just curious, what is the advantage of capturing in PPro 2?
Best,
Christopher
Old May 23rd, 2006, 12:55 AM   #7
PP Capture
If ver 4.0 is similar to previous versions you use Cineforms capture tool not PP. Once capture you import the footage into PP. Using Cineforms tool allows you to capture all the funky 24 modes out there.
Ernesto Sanchez is offline   Reply
