XL H1 Custom Presets Download Library - Page 8 at DVinfo.net
Old October 27th, 2008, 09:11 AM   #106
Custom Presets
Thanks so much for your help.
Denny
Denny Thompson is offline   Reply With Quote
Old October 27th, 2008, 10:46 AM   #107
You are most welcome.
Freddie.
Freddie Hoekerd is offline   Reply With Quote
Old October 29th, 2008, 05:07 AM   #108
Freddie,
Could you tell me please when you recorded all your clips for each pre-set did you use a manual white balance, auto or bright sunlight 5,600k setting?
Regards
Mick
Mick Jenner is offline   Reply With Quote
Old October 29th, 2008, 11:21 AM   #109
The setting was 5,600k
Freddie
Old October 29th, 2008, 11:24 AM   #110
Many thanks for that
Mick
Old June 16th, 2009, 04:24 AM   #111
Panavision preset for xh a1
Can someone please be so kind of pointing me to the panavison preset ? I canīt find it. Thanks.
Leo Bolanos is offline   Reply With Quote
Old June 16th, 2009, 08:13 AM   #112
Preset 10 - it is named Disjecta
On the first page of this thread
John Richard is offline   Reply With Quote
Old August 14th, 2009, 10:39 PM   #113
Updated Presets?
I'm no expert with Excel, but here's a spreadsheet covering all of the user-submitted XL H1 custom preset files that I've been able to dig up around here. So far there are seven from Alister Chapman; two each from Luis de la Cerda, Steven Dempsey and Lauri Kettunen; and one each from Oleg Kalyan, Daniel Epstein and Bill Taka. The sheet is called "v.20060604" in order to keep track of its date. I hope it grows up to be a lot bigger!
The actual .CPF files to follow in other posts below.
*updated 2006 / 05 / 20 -- added B&WJECTA and OLEGWARM*
*updated 2006 / 05 / 30 -- added DVXMATCH, EOSPHOTO, NATURALO and OUTSIDEN*
*updated 2006 / 06 / 04 -- added PANALOOK
This post (and the Excel file) is 3 years old. Is there an updated one floating around somewhere?
Alex DeJesus is offline   Reply With Quote
Old October 9th, 2009, 04:31 PM   #114
Data err
Hey all,
Just got my XH A1S today--I'm stoked.
I loaded all 18 presets onto the Canon-provided SD card into a PRESETS folder. The camera shows "DATA ERR" for 1-7, but 8-18 are fine. Any ideas?
Duke Networks, LLC
www.duke.net
Chris Duke is offline   Reply With Quote
Old November 12th, 2009, 06:04 AM   #115
Presets
The camera's quite sensitive to anything out of the ordinary on the SD card, I think that includes the archive and read only attributes.
If it helps, there's a tasty video here that shows 18 presets in action :
and there's a whitepaper on Canon's website describing the different options available in custom presets : http://downloads.canon.com/cpr/softw...ImageSetup.pdf .
Last edited by Aaron Scheiner; November 12th, 2009 at 06:05 AM. Reason: stupid mistake
Aaron Scheiner is offline   Reply With Quote
Old February 25th, 2010, 09:50 AM   #116
HVX200 preset?
I have an HVX200 preset I created for my XHA1. Since the settings adjustments are different and the presets are incompatible I cant use it with my newly purchased XLH1. The way I set up the HVX preset was on multi-camera shoot. The production company I mainly freelance for has an HVX and we had it and my XHA1 hooked up to a calibrate-able production monitor. We aimed both cameras at the same scene and tweaked settings while swapping back an fourth between the two cameras on the monitor until they reasonably matched. It worked out pretty well. I can probably do the same thing with my boss's HVX at the office on a test pattern. Is this a good method for creating a preset? Does anyone know if there is an HVX200 setting around for download for the XLH1?
Stephen F. Bodi is offline   Reply With Quote
Old March 12th, 2010, 09:51 PM   #117
Stephen,
According to the Excel Spreadsheets for each camera's presets a general rule for the color settings is that the XH A1 is 4x's higher than the XL H1. As an example:
XH Custom Preset
PANALOOK NAME
CINE2 GAMMA
LOW KNEE
MIDDLE BLACK
-7 MASTER PED.
-1 SETUP LEVEL
1 SHARPNESS
MIDDLE H DTL FREQ
0 DTL HV BAL
0 CORING
OFF NR
OFF NR2
CINE2 COLOR MAT.
4 COLOR GAIN
0 COLOR PHASE
8 R GAIN
8 G GAIN
12 B GAIN
0 RG MATRIX
0 RB MATRIX
0 GR MATRIX
0 GB MATRIX
0 BR MATRIX
0 BG MATRIX
XLH1 Custom Preset
PANALOOK NAME
CINE2 GAMMA
LOW KNEE
MIDDLE BLACK
-7 MASTER PED.
-1 SETUP LEVEL
1 SHARPNESS
MIDDLE H DTL FREQ
0 DTL HV BAL
0 CORING
OFF NR
OFF NR2
CINE2 COLOR MAT.
1 COLOR GAIN
0 COLOR PHASE
2 R GAIN
2 G GAIN
3 B GAIN
0 RG MATRIX
0 RB MATRIX
0 GR MATRIX
0 GB MATRIX
0 BR MATRIX
0 BG MATRIX
You can download the Excel Spreadsheets to compare them yourself. XH A1 here: http://www.dvinfo.net/forum/canon-xh...rary-copy.html
It's the first attached file in the first post.
XL H1 here: http://www.dvinfo.net/forum/canon-xl...d-library.html
Same deal.
OpenOffice.org - The Free and Open Productivity Suite is a free program that'll allow you to view these.
Could you please post your HVX200 preset for the XH A1? Did you use the Cinelike D gamma & Cine-like color matrix on the HVX? Thanks.
John Chance is offline   Reply With Quote
Old August 24th, 2010, 01:37 AM   #118
Data Error
Hi,
so I downloaded all the Custom Preset files, which I would like to thank for.
But the first 7 01-07 seem to have some kind of a issue. When I try access the files I receive a Data Error.
Now the rest work fine! Any advice? Thanks
Apple Pro
Shaggy Franks is offline   Reply
