Manual exposure at DVinfo.net
Old May 4th, 2006, 02:21 PM   #1
Manual exposure
In manual mode the iris can be closed to F9.5 The next stop is close.
In bright conditions 9.5 is not enough to retain say 1/50 shutter.
Now, in auto mode, when I press the exp.lock button I see iris levels all the way down to F22. How come I can't do this manually?
Kristian Indrehus is offline   Reply With Quote
Old May 4th, 2006, 02:38 PM   #2
Per, I cannot give you a straight answer to your question. However, you'd want to avoid closing the iris much further than f/9.5 due to diffraction effects anyway. Instead, use ND-filters - if necessary an additional one to the one built into the stock lens. Here's an interesting article on iris-induced diffraction effects:
http://www.luminous-landscape.com/tu...fraction.shtml
Incidentally, I've been thinking about buying a variable ND-filter. Although expensive, such a filter would enable me to shoot at the aperture/shutter speed of choice most of the time, independent of lighting conditions. Does anyone have experience with variable NDs?
HTH,
Ron
Ronald P. Pfister
halimedia - digital solutions and services
www.halimedia.com
Ron Pfister is offline   Reply
