1080i/24f and DSR-1500 A DVCAM Dubs-Timecode issue? at DVinfo.net
Old March 18th, 2006, 01:19 AM   #1
I know that the XLH1 uses HDV, which is MPEG compressed format, will I have Timecode issues if I perform an i.Link FIrewire dub to a DSR-1500A DVCAM tape? Do I need an SDI cable, or will Firewire alone do it? I asked about this earlier, if anyone has thoughts on this, please chime in. If this works, it could be a very low budget solution to making DV dubs from HDV, if they have access to a deck (through work or school), but little money for Dubs. Also, if you have a G4 like I do, and cannot invest in a G5, and cutting HDV is taxing on your system.
Brad Schreiber is offline   Reply With Quote
Old March 18th, 2006, 12:03 PM   #2
If you think you can convert HDV to a DV deck by just playing back HDV through Firewire, I doubt it would work. You can use the camera's downconvert function and dub through firewire and it should maintain timecode too.
Barlow Elton is offline   Reply With Quote
Old March 18th, 2006, 01:26 PM   #3
D'oh!
Sorry, I didn't realize the XLH1 had a downconvert feature, that solves a lot of problems. Thanks!
