TYPICAL and BEST CASE H. Rez.? at DVinfo.net
Old March 17th, 2006, 04:38 PM   #1
HDV Cinema
According to Wilt's "wobulation" test of the XL H1 -- it's "worst-case" H. Rez. is 800 TVL/ph. (I think he noted slightly less than 800 TVL/ph.)
My math model estimates this result, exactly.
But, it also predicts much higher TYPICAL (900 TVL/ph) and BEST CASE (975 TVL/ph) numbers.
1) So, who using the same charts as Adam, has measured resolution without wobulation? What number did you arrive at?
2) Using any commercial chart, what did you arrive at?
I'm simply trying to confirm my math model isn't over estimating the resolution from the H1.
Steve Mullen is offline   Reply
