XL-H1 Overcrank clip! - Page 4 at DVinfo.net
Old March 2nd, 2006, 01:03 AM   #46
Guest
Posts: n/a
Originally Posted by Barlow Elton
I'll have to give it a try. I believe what you'll end up with is 1920x540 fields interpolated vertically to be 1920x1080 60p
You need to end up with 1920x540 filelds interpolated vertically to be 1920x1080 from 1080/60i, right?
then converted to 1080/24p. So the motion will look pretty much like 2.5 "overcrank", but not necessarily all that sharp. The actual detail and results I think will be very similar to taking true 1280x720 and bumping up to 1080p.
Why not better if 1920x540 = 1,036,800 is higher than 921,600 (1280x720)?
Regardless, it can look pretty good and reasonably slow for dramatic purposes.
So the pretty look results that you have been to prove that it's possible to get slowmotion from XL-H1 through HD-SDI to DVCPRO-HD at 720p, it means that will it be viable to have it from any kind of 1080i source like 1080i Canon's itself or any Sony's HD series, Cinealta or HDV -- right?
