Quick Question[s] at DVinfo.net
Old January 17th, 2006, 12:21 AM   #1
Quick Question[s]
Q1. Does the camera have the standard 20pin hirose connector that allows the use of a B&W viewfinder?
Q2. [Kit wizards only...] And this is compatible with the SONY DXF 801 viewfinder? [if you are a total kit wizard....]
I have a SONY vf that I might use with the camera + mini 35....if it works.
John Colette is offline   Reply With Quote
Old January 17th, 2006, 08:42 AM   #2
John, it does have the ability to have a B+W viewfinder, but only if you use the canon one, I don't believe a sony one will fit, but I'll double check. It would be great to use a REAL high def viewfinder on this camera.
I have a dream that one day canon will release a 35mm ef to xl adapter and I'll have iris control and a 35mm dof of all my ef lenses, and it will be awesome...
Nick Hiltgen is offline   Reply With Quote
Old January 21st, 2006, 08:23 PM   #3
Thanks Nick - the option for B&W is a good one, I am thinking about fitting my mini 35 with the camera - and was wondering if i would need the breakout box, or if i could go with the Canon VF.....
