Pete-Did you get it yet? - Page 4 at DVinfo.net
Old December 9th, 2005, 06:13 PM   #46
hi Pete,
do you know if accessories like the CH910 still workis?
bow wow wow
Yi Fong Yu is offline   Reply With Quote
Old December 9th, 2005, 07:05 PM   #47
Yup, it will.
The complete XL H1 accessory list is at the end of the owner's manual (see sticky thread at the top of the forum: http://www.dvinfo.net/conf/showthread.php?t=55123) and also on the Canon web site (http://consumer.usa.canon.com/ir/con...modelid=12152), and they do list the dual charger, along with most other existing XL accessories.
The new "G" batteries are rated at 7.4V rather than 7.2, but are compatible with older XL's and of course with the H1, and seem to have an unnaturally long charge capacity (see the user's manual for Canon's specs on this). All the testing I've done so far (Hi1 powered on for at least a couple of hours) and the standard "G" battery is barely off of "full."
Pete Bauer
Old December 13th, 2005, 12:32 PM   #48
Thanks for all the info Pete, good stuff!!
Any chance of getting some high quality still frames? (a la the new HVX stuff?)
Any would be greatly appreciated. Have fun with the camera.
Jim Exton is offline   Reply With Quote
Old December 13th, 2005, 10:01 PM   #49
Here are 4 starting at http://www.pbase.com/agamid/image/53530487. All 1080i HDV frame grabs captured to FCP5 and exported via Quick time to JPEGs. Re-sampled to 1920 x 1080 in Photo Shop.
Old December 14th, 2005, 08:21 AM   #50
Images: 1
So A.J., can we assume you are a proud owner of the new H1? If so, congratulations!
-gb-
Old December 14th, 2005, 09:41 AM   #51
Yes, thanks, and I am most impressed with it. After 60 years of looking at NTSC SD it's as if someone has turned the lights on!
Old December 14th, 2005, 10:05 AM   #52
Ok A.J., you tipped your hand...at last there is another DVinfo'er with an H1. CONGRATULATIONS!
And since you're technically far more knowledgeable than I am, GET YOUR BUTT TO WORK and do all kinds of torture tests right away! ;-) If you're able to verify the favorable results of my crude tests, that would be wonderful, and I'm sure that you can do a lot better and more detailed job of it.
Sorry, folks, I've been busy this week with things far less entertaining than playing with my new H1, but should have more time this weekend. Top two on my list are pushing to see what it takes to break the inter-frame (GOP) compression (always a contentious topic when people are talking theory but don't have facts/tests), and simply to get some real-world, non-test clips posted for other folks enjoyment/amusement. A.J., anything you can post will be greatly appreciated.
Cheers and again, congrats!
Pete Bauer
Old December 14th, 2005, 02:50 PM   #53
Is the Optical Image Stabilizer of great advantage?
I wonder how efficient the OIS, Optical Image Stabilizer is?
Is it of good advantage if you like to use the camera without tripod?
Is it definitely a feature to have that you should not choose another camera without OIS? I appreciate it in a still camera like my Canon D60 but how good is it for video with panning camera etc?
Johan Forssblad is offline   Reply With Quote
Old December 14th, 2005, 02:58 PM   #54
Pete/AJ: don't forget to test and post examples of the lowlight capabilities.
Regarding breaking the compression, try mounting the camera on a tripod/dolly setup and rolling it across a rough surface. That's the kind of movement which causes trouble on the Sony HDV cameras.
Old December 14th, 2005, 03:25 PM   #55
I'll comment at this point that one of the most impressive things for me about the XL-H1 is that the codec seems to work so well. I did not pick I frames to post because I have no way to tell whether a chosen frame is an I frame, P frame or B frame. Stepping through captured (FCP5) video frame by frame gives no clue as to which frames are which. I tried to "break" the system by putting the camera on a tripod and turning it through 360 degrees as fast as I could. The frames naturally look blurry but the blur appears to be no different from that which you would normally associate with the blur from the shutter speed.
Old December 14th, 2005, 03:36 PM   #56
A.J. From what I've seen in my own experience and other people's comments, where HDV suffers problems is if the camera experiences a strong vibration or sudden bump. I particularly notice this when my FX1 gets jarred up and down, but a sideways knock should do the same thing. Would be interesting to know if you can replicate this on the XL-H1.
P.S. Best solution is reportedly to insulate the camera from shock and vibration by any means available, like foam or a beanbag or something.
Old December 14th, 2005, 04:09 PM   #57
Thank you very much. Beautiful stuff!
Old December 14th, 2005, 05:11 PM   #58
Barry Wan Kenobi
It certainly does. At the DV Expo booth, they showed some quite-challenging scenes, rippling water scenes etc., which would have given the Sony some serious challenges, but the Canon showed no ill effects at all. I don't know if it performs better in 60i, but in 24F it certainly seems to be well optimized -- the fact that it's encoding 20% fewer frames, plus that each frame is about 20% softer in detail, plus that the frames get encoded using the more-efficient progressive method rather than the less-efficient interlace method, all add up to the 24F HDV encoding looking very solid.
Old December 15th, 2005, 06:40 AM   #59
Images: 1
That's the same feeling I got after getting an HDTV and watching some of the stuff on PBS and HDNET back in 2002.
-gb-
Old December 15th, 2005, 06:58 AM   #60
Blue and red ghosting
Hey Pete,
Many thanks for putting up the rez chart tests - I found them very informative. The notion that the older SD glass would work fine confirms my earlier suspicion when I was asking for a body only version - maybe that will come later as the demand grows.
What I did find most interesting is that the blue and red ghosting ( which was noted on some early tests from France) seems to be present for both the SD and HD glass - however there seems to be none of it present when the SD glass is fitted to the XL2. This would suggest that the glass is not at fault but the problem lies elsewhere.
Looking in Photoshop at just the blue and red channels independently, the ghosting is confirmed as it is quite clearly burnt into the image; the green channel is perfect. It is difficult to fathom but I suspect some low incidence light is bouncing around between some flat surfaces before it gets to the CCDs.
I wonder if other owners can confirm this blue/red ghosting? Also would it be possible to repeat a test at maximum aperture to see if it is any worse?
John Jay
Beware ***PLUGGER-BYTES***
John Jay is offline   Reply
