Question on HD-SDI out with peaking at DVinfo.net
Old September 20th, 2005, 11:17 AM   #1
Skyonic New York
it is my understanding that when recording out through HD-SDI with peaking on, peaking is recorded to your HD-SDI source...
can anyone confirm this?
Robert Mann Z. is offline   Reply With Quote
Old September 26th, 2005, 09:33 AM   #2
Skyonic New York
ok i finally got my answer...yes indeed if you turn peaking on it will be output via HD-SDI, which i guess is good and bad...if your external monitor is not true hd resolution, bad if your going to a deck
i can see a setup where peaking is turned on for a setup on a shot and then forgotton to be turned off...it would make working with peaking a bit more tricky...
